Visit www.genswiss.com for additional information on various cutting oil formulas available.
Genevieve Swiss Industries, Inc., offers new formulations of “Swiss Silver” cutting oils specifically designed for greater lubricity, faster heat dissipation, improved part finish and longer tool life in Swiss type machining applications. Several types of “Swiss Silver” are available to suit “soft” and “hard” metal applications. The unique formulation of “Swiss Silver” serves to eliminate wax-like buildup on machine's slide surfaces that can catch chips that create abrasion, loss of accuracy and high machine maintenance costs. All formulations are clear allowing for greater operator visibility while lower viscosity results in less fluid use, less fluid carry out on parts and less chance of tolerance change as machine oil temperature increases. In addition, “Swiss Silver” features high-pressure delivery capability for low mist, low foam and low air entrapment ensuring the oil remains inside the machine and does not go into the air in the shop.
