584,808 active members*
5,362 visitors online*
Results 1 to 7 of 7
    Jul 2008
    13
    Siemens alarm 2100
    Hello, we have a fadal vmc4525 with a siemens 840d controler. we just recently started getting an alarm ; 2100 nck battery warning threshold reached. can not reset it, we have to restard machine and it goes away for half an hour or untill new program is loaded. does anyone know how to resolve this issue? thanks,
    900
    The alarm is trying to tell you that the NCK back up battery needs replacing.
    Neal
    Jul 2008
    13
    is it the small green 3v lithium battery on the back of the controler?
    900
    Select--
    This sounds right. I don't have a machine here that I verify it with and we haven't been using the Siemens control for a few years now. My mind is a little foggy.
    Neal
    Jul 2008
    13
    thanks for your help, found the problem it was the battery on the mci board.
    Mar 2004
    22
    Yes the battery with the wires soldered on.
    there is also a battery in the pendent on our machine.
    worth a look to see and replace.
    if not replaced you loose ALL your paramiters and settings. not good
    geo
    www.egwguns.com
    Learning
    Oct 2006
    840D NCK fan alarm
    I had the same problem and replaced the battery in the pendant,
    but after a few days the NCK fan alarm appeared again.
    The guys at Fadal or Siemens all said "You changed the battery,well that should have fixed it."
    Over the next few days I tried various things, even installed a monster battery(10 times bigger in capacity),but nothing changed.
    I googled Siemens 840D battery and somehow found a pdf file for a punch press
    where the SECOND battery was shown.It is located in/next to the cluster of axis amplifier boards inside one of the white motion control boxes.
    You basically pull on a small drawer that holds the battery and
    there is also a fan that blows onto that battery.This fan quit working
    on my machine.
    Anyway I replaced the battery and all is fine.
    Every once in a while I still get a Fan alarm because the fan is actually broken and I haven't replaced it.
    THE MACHINE MUST BE ON WHILE CHANGING ANY OF THESE BATTERIES!
    Thomas
  1. CICINNATTI MILACRON - ACRAMATIC 2100 ALARM-APC RACK 0
    By CHANDRU in forum Cincinnati CNC
    Last Post: 03-03-2015, 08:35 PM
  2. siemens acramatic 2100 control
    By jptalon in forum SIEMENS -> GENERAL
    Last Post: 09-19-2012, 12:00 PM
  3. Siemens alarm 43 please help
    By cdfracing in forum Hyundai Kia
    Last Post: 03-13-2010, 01:37 AM
  4. Cinci Arrow w/2100 Siemens 611 error
    By cnccalgary in forum Cincinnati CNC
    Last Post: 09-28-2009, 10:29 PM
  5. Acramatic 2100
    By mblazenby in forum Tree
    Last Post: 02-05-2009, 02:30 PM
