585,978 active members*
4,285 visitors online*
    Mar 2006
    92
    Feedrate Setting In Post
    This pertains to lathe. The generic post works great for me except when threading. It posts out an "E" instead of an "F". Once I edit to F everything runs good. It only puts the E when threading. All other operations use an F. So where in the post can I change to get the F I need?
    Phoodieman
    Aug 2008
    5
    it easy to do .
    open the post -> goto here
    # General Output Settings
    force_wcs : yes$ #Force WCS output at every toolchange?
    progname$ : 1 #Use uppercase for program name
    css_start_rpm : yes$ #Do direct RPM spindle start prior to CSS?
    css_end_rpm : yes$ #Do direct RPM spindle prior to Retract?
    prog_stop : 1 #Program stop at toolchange: 0=None, 1=M01, 2 = M00
    tool_info : 3 #Output tool information?
    #0 = Off - Do not output any tool comments or tool table
    #1 = Tool comments only
    #2 = Tool table only
    #3 = Tool comments and tool table
    use_pitch : 0 #0 = Use feed for tapping (force Feed/Min), 1 = Use pitch for tapping (force Feed/Rev)
    rigid_tap : 1 #0 = Floating tap output
    #1 = Rigid tap output (Set parameter 5200 bit 0 to 1 for rigid)
    #(Set M code for rigid tap in parameter 5210)
    tap_feed : 1 #0 = 2/1 (in/mm) decimal places, 1 = 4/3 (in/mm) decimal places
    thread_address :1 #Thread pitch address for lathe threading, 0 = Use F, 1 = Use E
    change number 1 to 0 at red color, you will got F instead of E .
    hope it will help .
    Mar 2006
    92
    Feedrate
    Quote Originally Posted by concoo View Post
    it easy to do .
    hope it will help .
    This is the General Settings Info....no mention of feed rate there. I have looked for the thread addres info. Couldn't find that. Has to be in the post somewhere I just can't figure out where. I checked the G76 section. couldn't see anything having to do with feedrate.
    sub_level : 1 #Enable automatic subprogram support
    breakarcs : 1 #Break arcs, 0 = no, 1 = quadrants, 2 = 180deg. max arcs
    arcoutput : 1 #0 = IJK, 1 = R no sign, 2 = R signed neg. over 180
    arctype : 2 #Arc center 1=abs, 2=St-Ctr, 3=Ctr-St, 4=unsigned inc.
    do_full_arc : 0 #Allow full circle output? 0=no, 1=yes
    helix_arc : 0 #Support helix arc output, 0=no, 1=all planes, 2=XY plane only
    arccheck : 1 #Convert small arcs to linear
    atol : .01 #Angularity tolerance for arccheck
    ltol : .002 #Length tolerance for arccheck
    vtol : .0001 #System tolerance
    maxfeedpm : 500 #Limit for feed in inch/min
    lcc_move : .05 #Enter the move in X, Z for lathe canned cycle comp.
    ltol_m : .05 #Length tolerance for arccheck, metric
    vtol_m : .0025 #System tolerance, metric
    maxfeedpm_m : 10000 #Limit for feed in mm/min
    lcc_move_m : 1.25 #Enter the move in X, Z for lathe canned cycle comp.,mm
    force_wcs : yes #Force WCS output at every toolchange?
    spaces : 1 #Number of spaces to add between fields
    omitseq : no #Omit sequence numbers? (use -1 to enable sequence for LCC)
    seqmax : 9999 #Max. sequence number
    nobrk : no #Omit breakup of x, y & z rapid moves
    progname : 1 #Use uppercase for program name
    rotaxtyp : 3 #Rotary axis type for toolplane
    tooltable : 3 #Read for tool table and pwrtt (3 recalls pwrtt at sof)
    ref_ret : 0 #G29 / G30 return variable from Mi3
    css_start_rpm : yes #Do direct RPM spindle start prior to CSS ?
    Phoodieman
    Mar 2006
    92
    Solved: Change Feedrate from E to F
    I did a search for E and F and found this. I noticed the stre and strf callouts
    #String and string selector definitions for NC output
    #Address string definitions
    stra "A" #String for address A
    strd "D" #String for address D
    stre "E" #String for address E
    strf "F" #String for address F
    stri "I" #String for address I
    strk "K" #String for address K
    Then I searched for stre and found this....
    #Format feedrate for lathe thread
    result = nwadrs(stre, feed)
    result = newfs (19, feed)
    When I changed the stre to strf I got the F for feedrate in the posted out program. What a hassle.
    Phoodieman
  1. feedrate wire
    By qwerty1000 in forum Post Processors for MC
    Last Post: 10-26-2009, 04:11 AM
  2. 0i-MC feedrate is ignored after a tap cycle
    By jhartleyjr in forum Fanuc
    Last Post: 06-28-2009, 01:07 AM
  3. Could someone post there setting for a HY02D223B
    By Ed Williams in forum DIY CNC Router Table Machines
    Last Post: 05-20-2009, 06:23 PM
  4. G02, G03 Feedrate !!!!!
    By usb in forum CNC (Mill / Lathe) Control Software (NC)
    Last Post: 09-16-2008, 01:19 AM
  5. Help setting up post process from TCC to Mach3
    By 56speedster in forum Uncategorised CAM Discussion
    Last Post: 03-29-2008, 04:14 AM
