585,752 active members*
4,118 visitors online*
Thread: v23
Results 1 to 9 of 9
    Mar 2009
    291
    Angry v23
    How do i draw a circle tangent to two other circles?When i dont know where the center should be.
    Feb 2009
    2143
    Use the command "Arc 3 Entities". Use your two circles as two of the elements, and place a point (before this command) for the location of the third point (or use some other object as the third point. When you do this, you may not get a full circle. If you don't, you can select the three elements in the reverse direction to get the other part of the arc filled in, or you can put a point at the center of the incomplete arc, and use that to make a circle (delete the original arc after your place the center point, or put it on another layer, if you don't want it part of the "finished" sketch).
    Feb 2006
    992
    It's hard to answer your question 'cause depend how one radius locate respect relate to other one. Normally, draw the bigger radius first then after that the smaller radius.
    The best way to learn is trial error.
    Mar 2008
    29
    Quote Originally Posted by 1234567 View Post
    Basic geometric construction techniques serve this situation well.
    Offset the diameter of each circle by the radius of the new circle.
    The intersection point of these diameters will be the center point of the new circle.
    Use point intersection command to drop a point at this intersection.
    Then arc snap to drop the new circle at that point.
    Mar 2009
    291
    tangent circles
    need large circle tangent to two small circles
    Mar 2008
    29
    Like this?
    Mar 2009
    291
    circles
    Ya this is what i want. i did line tangent and then deformed it looks about right but i need the line to be a 6.00 raidus.
    Mar 2009
    291
    Smile
    Ok i see how you did it thanks for the help
    Mar 2008
    29
    NP, I always knew that 9th grade geometry class was good for something
