585,717 active members*
3,884 visitors online*
Results 1 to 6 of 6
    Jan 2010
    Maho 600 c rotary table
    Hello !
    Im new here, so hello to everyone!
    Recently I bought used cnc machine maho 600 c.
    The problem is that the rotary table (B-axis) doesnt work correctly.
    When you want to turn the table for some amount of degrees, he turns and then suddenly stops before than he should and all the motors turn of.
    On the screen says : "B 04 Max. following error too large".
    I think that the constants for B-axis (N 350- N 400) are not correct.
    So if anyone has this machine and can send me those constants, I would be very thankfull.
    Jan 2008
    124
    Make sure the "b" axis clamping cylinders are releasing. check if there is any mechanical binding. check that the "b" axis motor is secure and the mounting bolts of the motor thightened.
    Mar 2007
    64
    it could be a constants problem or an encoder or the cable between the encoder and the drive. i'm attaching a list of constants from a 500C with a rotary axis.
    I also attached a list from an 800C. Hope it helps, if not shout
    Attached Files Attached Files
    Jan 2010
    Thanks for help !
    We will try with these constants.
    May 2020
    Re: Maho 600 c rotary table
    Need help please
    I have maho 800 e2
    The problem is that the rotary table (A-axis) doesnt work correctly.
    On the screen says : "A 09 Max. following error too large".
    Is any one know why
    Oct 2018
    11
    Hi, the error says the difference between actual position and programmed/expected position is too high. Are there any other alarms ?
  1. Adding a rotary encoder to a large Rotary Table
    By small.planes in forum Mechanical Calculations/Engineering Design
    Last Post: 04-27-2012, 07:27 PM
  2. maho 1000C. maximum weight on table
    By shay z in forum Deckel, Maho, Aciera, Abene Mills
    Last Post: 04-14-2009, 01:51 AM
  3. Need help deckel maho dmc 160u with rotary table
    By dr1 in forum Deckel, Maho, Aciera, Abene Mills
    Last Post: 01-25-2009, 08:05 PM
  4. Help with rotary table
    By woodsnskins in forum Linear and Rotary Motion
    Last Post: 12-18-2008, 11:58 AM
  5. 60$ rotary table?
    By vacpress in forum Uncategorised MetalWorking Machines
    Last Post: 10-30-2007, 01:12 PM
