I am new to the forum and would appreciate any help I can get. I will try to describe this the best i can. I have a rectangular shaped hollow part with . 060 wall thickness. I need to make a simple 2d cut around the part with my cutter only entering about .150 deep. This will seperate the part into (2) pieces. The cut contains lines and arcs. I am not that familiar with programming the 4th axis in mastercam, I did get it to run my path and rotate the part, but the tool is not perpendicular to the plane it is cutting.
Any advise will be very helpful.
Thank you
