586,000 active members*
4,829 visitors online*
IndustryArena Forum > Events, Product Announcements Etc > Polls > How many of you have .00005 Indicators and what do you use them for???
View Poll Results: How many of you have .00005 Indicators and what do you use them for???
Voters
385. You may not vote on this poll
  • Yes
    115 29.87%
  • No
    270 70.13%
Page 3 of 3 123
Results 41 to 51 of 51
  1. #41
    Jan 2006
    4396
    Quote Originally Posted by neilw20 View Post
    About 1/25th of an average 1 thou hair from my head.:wave:
    That is some thin hair, LOL. Mine on average is .003 to .004 thick, even the silver ones
    Toby D.
    "Imagination and Memory are but one thing, but for divers considerations have divers names"
    Schwarzwald
    www.refractotech.com
  2. #42
    Jun 2007
    3757
    Talking Ouch. I just re measured.
    Head hair. 0.001"
    Beard 0.004" Guess there are a few others that size too.
  3. #43
    Jan 2008
    66
    Question Engraving surface...
    Thanks neilw20, but if .00005" is used for engraving, but then, how FLAT is surface required to be? is this possible in a job shop environment (just curious)?
  4. #44
    Mar 2009
    4
    Machine setup.
  5. #45
    Jan 2006
    4396
    Quote Originally Posted by cncprofessor View Post
    More than likely .0002 to .0005. The rule for inspection equipment per application is the tolerance divided by 4. Most shops do not follow this rule mainly because they do not have experienced help.
    Toby D.
    Schwarzwald
  6. #46
    Jan 2008
    66
    Stated print tolerance vs. inspection equipment calibration
    Okay, so the mentioned .00005” applies to the inspection equipment capacity/calibration rather than to the stated tolerance on the print, right? As far as the inexperienced help go, that is unfortunately - very true!
  7. #47
    Jan 2006
    4396
    To put it as simply as possible. You should have inspection equipment that is more accurate than what your measuring.
    A good example is using a Micrometer with .0001 Graduations to check a +-.0005 Tolerance on an OD. You should not be using a Dial Caliper, Vernier, or Digital Caliper. These are the wrong instruments.
    Toby D.
    Schwarzwald
  8. #48
    Jan 2008
    66
    Exclamation
    Quote Originally Posted by tobyaxis View Post
    Thanks tobyaxis, I got it! Just as I thought, the .00005 is for inspection equipment accuracy/calibration rather than for measuring the print tolerance of .00005, otherwise we would need to use a measuring tool to .0000125" measuring capacity.
    PS - I admit, I should have red first original post before I posed the question.
  9. #49
    Jan 2006
    4396
    LOL, it's all good.
    Toby D.
    Schwarzwald
  10. #50
    May 2008
    18
    i use mine for resetting the magazines on my pops coffee table after visits...should one go askew...yikes!(nuts)
  11. #51
    150
    Used for setting up the boring head on a lathe.
Page 3 of 3 123
  1. LED indicators on stepper driver outputs
    By xkadet in forum CNC Machine Related Electronics
    Last Post: 04-17-2012, 05:04 PM
  2. Cheap dial indicators
    By 43220 in forum Want To Buy...Need help!
    Last Post: 01-28-2008, 10:34 PM
  3. Economic indicators - which do you use?
    By Chris D in forum Community Club House
    Last Post: 02-04-2006, 10:14 PM
  4. Proper use of dial indicators.
    By Cowbell in forum MetalWork Discussion
    Last Post: 01-23-2006, 11:37 AM
