Does anyone have experience with these x-axis 'bolt-on' power feed units? This particular one comes under the name 'Shars' but as usual, I have seen clones & look-alikes. I've also seen higher torque 'Bridgeport' units adpted to RF45 machines, but usually they have to make table adapter plates & leadscrew mods. This one looks pretty easy if I understand, remove the manual handle, mount the gear with integral matching spline & clamp the power unit on.
I wont include the ebay# because the link will die eventually, but here are some pics & specs.
TABLE POWER FEED MILLING FOR JET MACHINE RONG FU MILL NEW!
Description:
X Travers
Torque: 135in/lb
For 5/8" Shaft with 3 jaw chuck coupler
For table model mill and drill machines with 135in/lb of torque
Easy to install, no modification needed
High quality design and construction
Circuit panel is designed for easy replacement with insert type connectors
Clutch gear assembly has torque limit
When power feed is working and accepting a tremendous obstacle, the clutch gear assembly will automatically disengage the power feed in order to reduce damage
Instructions manual included
Speed range is 0-165rpm
Voltage: 110v
Mounting Adapter Accessories:
The power feed is connected to the lead screw via a 3 jaw chuck coupler with teeth on the outer ring, particularly JET milling machine
