585,981 active members*
4,093 visitors online*
IndustryArena Forum > MetalWorking Machines > Fadal > Spindle motor overload
    Dec 2005
    114
    We have an 85 4020. Tried to turn on the spindle today and got a "spindle motor overload" alarm. It has an upgraded drive (Baldor) which has been running flawlessly for years. The only thing I can find is fuse 9 keeps blowing. The panel says its for the spindle cooler & motor fan. I think it is keeping the drive from powering up because there is no display on the LED spindle drive display. 3 phase power thru the fuses before the drive is good.
    Do you think the problem is in the fan motor? This machine has been so reliable I am puzzeled where to begin or what are common factors.
    Jul 2009
    317
    If the Baldor is an old one (lite brown) there a couple of fuses inside; and also look for
    small round red resistor they tend to break loose because of heat.
    Check the K relays in the back cabinet, the controller card connection, Spindle orient
    hall effect switch.
    Dec 2005
    114
    Thanks for the tips, I will check em out tomorrow. My f9 fuse is unrelated. I think the Baldor drive is gray. I think there may be some fuses under the top boards. After hitting a M03 there is a bit of a delay and sounds like it is winding up before it delivers the fault. I think it is the drive. It has been very good, much better than the original, I think sweeo. I blew a few of those toshiba transistor packs.
    Thanks again.
  1. Help....spindle overload fault message
    By icedog in forum Dynapath
    Last Post: 10-12-2009, 04:45 PM
  2. Spindle Overload Monitoing....
    By Sump Cleaner in forum Fanuc
    Last Post: 08-28-2007, 07:41 PM
  3. spindle motor overload
    By RdHawg in forum Uncategorised MetalWorking Machines
    Last Post: 12-06-2006, 08:02 PM
  4. Spindle overload switch
    By Anchor in forum DNC Problems and Solutions
    Last Post: 05-26-2006, 07:18 PM
  5. Spindle motor overload, DX 32 control
    By Gncc50 in forum Bridgeport / Hardinge Mills
    Last Post: 11-15-2005, 07:49 AM
