585,760 active members*
3,734 visitors online*
    Jun 2009
    108
    Unhappy Mitsubishi Spindle Drive Alarm
    I need help about alarm F4 6F in spindle drive display (Drive MDS-A-SP-220) , this alarm appears flashing on the display, I tried to find this alarm in the manual but Isn't appears any information about, someone could help me, please?
    MELDAS 500 CONTROL
    24220
    In my manual the 6F alarm is a error in the power supply A/D converter, or other error in the power supply itself.
    Al.
    Albert E.
    Jul 2007
    284
    Yeah 6F is a power supply alarm. The power supply throws its alarm on the connected spindle drive unit. More then likely your power supply is blown due to old age. Yours should be an MDS-A-CV-#. Mitsubishi doesn't support that drive anymore but they can sell you a newer version that is a direct replacement. You can call them at 847-478-2500.
    Aug 2009
    71
    6F
    1) Check from Spindle alarm History, any other alarm appeared before 6F.
    2) Check CN4 (CV) to CN4 (SP) cable SH21 is connected properly.
    3) Check CV Rotary sw. setting.
    4) Check value of SP041 = 22
    Ref attached for diagnosis
    Re: Mitsubishi Spindle Drive Alarm
    i have a drive MDS-B-SP-J2-04 error A/D converter , please help me....
  1. Replies: 0
    Last Post: 04-30-2014, 04:42 PM
  2. Mazatrol with Mitsubishi drive and 61Y/35Y over regeneration alarm and estop.
    By Inputflangeman in forum Mazak, Mitsubishi, Mazatrol
    Last Post: 03-12-2014, 04:47 PM
  3. Mitsubishi FR-SGJ Spindle Drive
    By mikwest in forum Mazak, Mitsubishi, Mazatrol
    Last Post: 04-29-2010, 10:03 PM
  4. Mitsubishi DL MAZ Spindle Drive
    By nnpepe in forum Mazak, Mitsubishi, Mazatrol
    Last Post: 03-27-2009, 10:30 PM
  5. Mitsubishi spindle alarm 5022
    By mroy0404 in forum Mazak, Mitsubishi, Mazatrol
    Last Post: 04-26-2007, 03:11 AM
