Hi Ray L
Been reading the posts and to be honest it sounds more like 5083 that 6061, to be fair I`ve never actually come across any 6061 in plate form, it is normally an extruded Alloy as far as I know!!
I`d be inclined to check with the supplier, I had a similar issue a few weeks ago, I ordered some 3 3/4" round bar 6082 T651 grade Alloy pre-cut to 2" billets, out of the 100 pieces 3 of them were a different material and I had exactly the same issues as you, luckily I was turning the pieces up on the Lathe first before milling and they just didn`t "chip" properly, I sent them back with the suppliers Rep for checking and it seems someone used some softer material to make up the numbers as it were, that did turn out to be 5083, really soft, I only turned one down to shape and had to change all my feeds and speeds to do it!!!
The other 97 pieces turned and milled fine so I think you need to go back to the supplier and check out the specification of the material!!
End of the day a spec is a spec, if it says 6061 T651 "on the tin" then the composition, hardness, heat treatment and stress relief should be the same regardless of the shape it comes in!!
Check the material specs here,
http://www.azom.com/Details.asp?ArticleID=3328
from these specs it should machine OK, if you use the same site to check the 5083 you will see it says very poor machining ability!!
Regards
Rob
