585,948 active members*
3,663 visitors online*
IndustryArena Forum > WoodWorking Machines > DIY CNC Router Table Machines > Aluminium profile - Fixed gantry questions
Results 1 to 1 of 1
    Jun 2005
    21
    Hi All
    Get very close to locking this design in and start the parts order.
    It will be fixed gantry with moving table in one axis (other will be across gantry)
    Cutting area will be around 350mm x 620mm x 120mm.
    Will be used for PCB manufacture, routing fibreglass and carbon fibre panels, wood, plastic and anything else used in RC.
    Slides and ball screws from ebay store LineraMotionBearings. Will be built from Al profile (similar to 8020) but in 60mm x60mm, 2 slots per side. This is perfect as they will line up with the width of the holes in the support rails for the slides.
    Steppers will be in the 250-350 range. Basic controller to start with and then move up to gecko later.
    Does anyone have any comments on the above in particular to the slide placement? The ones on the gantry are to the top and bottom of the profile with the centre line of the shafts 174mm a part.
    Gareth
    PS: Google SketchUp sucks. What is a good FREE 3D cad program?
  1. Fixed gantry router
    By KTP in forum DIY CNC Router Table Machines
    Last Post: 04-17-2011, 11:44 PM
  2. fixed gantry
    By eloid in forum DIY CNC Router Table Machines
    Last Post: 01-29-2009, 11:20 PM
  3. Fixed Gantry Machine
    By solodex2151 in forum DIY CNC Router Table Machines
    Last Post: 09-04-2008, 11:17 PM
  4. Moving or fixed Gantry ??
    By xairflyer in forum DIY CNC Router Table Machines
    Last Post: 02-21-2005, 05:54 PM
  5. Fixed Gantry
    By Auzze in forum DIY CNC Router Table Machines
    Last Post: 07-25-2004, 08:34 AM
