586,005 active members*
5,274 visitors online*
IndustryArena Forum > Hobby Projects > RC Robotics and Autonomous Robots > Eclipze's SMD Pick'n'Place Build....
Page 1 of 37 12311
Results 1 to 20 of 733
    Oct 2006
    461
    I've played around with quite a few designs for a small hobby desktop pick and place machine in the last 2 years. But I've finally come down to a solution I'm going to build :-) It's actually the 20th design model
    There is of course many different approaches you can take. I've held a core theme for my design... small capacity desktop machine, light weight, support a flexible design for modifications and support fast movements.
    It's not a design for full blown production, rather a design suitable for prototyping or a short pre-production run. I specifically want it to support placement for components with footprint around the size of 0805, SOT23 and fine pitch IC like TSSOPs. The option for two placement heads has also been of interest. This is either for two different pickup nozzles, or to have one setup for paste dispension. I tend to machine my own stencils for small runs anyway, so the paste head mechanism hasn't quite been finished yet.
    Ultimately... this will never been anything like having a proper production machine. It's far more of a hobby... some people build ships in a bottle, others are happy to spend many late night procrastinating over a feather weight pick and place machine hahaa.....
    I am concentrating on the basics. Not the end goal. Vision based alignment, auto head changing, automatic feeders are all future upgrades. If I spent too much time looking into all the extras, I'd never actually get the first model up and running. So please bare that in mind with any comments.
    Basic design specs...
    X Axis Travel is ~160mm
    Y Axis Travel is ~440mm
    Z Axis Travel is ~25mm
    X & Y step resolution is 0.0125mm
    C Axis step resolution is 0.14 degrees
    PCB area is flexible, currently shown as 220x180mm
    I really wanted the design to have a lightweight head, to enable fast acceleration and also to keep the cost down. I've looked at many approaches using double rails and ballscrews, which always add a significant amount of weight and cost. However the more I played with the idea of light weight, the more I realised I could achieve a rigid design with just 3 linear bearings, belt driven. I have the igus Drylin T Series rails for X, Y an Z, and 2.5mm pitch, 6mm wide belts.
    The X and Y are using NEMA 17 motors, and the C is using a tiny 20x20x32mm stepper. All are bipolar 1.8 degree step. The Z axis are all controlled by RC servo motors. I sure a lot of people are going to choke on that one hahahaa.... I have picked servo motors for good reasons. They are light, very fast, inexpensive (consumable) and easy to drive with the electronics (no stepper drivers). They have a radial movement, which means their translated linear movement has variable precision. The way I have the mechanism set, I achieve the highest precision as the placement tip descends close to the board. In addition, if the tip over travels (tries to crush the part underneath), it can't. The only downward force the tip has is the weight of the carriage/head. Once touching the component, only this weight will be on the component, after which the servo bearing disengages from the mating surface. I'm hoping that although I may not have fantastic precision, I can safetly overdrive the placement without risk of any damage.
    The head has a separate tape indexing pin to feed the tape with. Each strip of tape also has a square box where the component is picked up, so component alignment by bumping can be done at the point of pickup. Rather than traversing to a specific cavity to perform the function.
    The C-Axis uses a rotary tube fitting, which is held in place by a large bearing. A gear is attached to the rotary tube fitting, whereby the stepper can rotate the bottom half of the tube fitting (which is connected to the pickup needle). The top isn't fixed, however the air tube will restrict it's movement anyway.
    I'm using ribbon cable for passing all data/power. All the actuators are so small, that the power requirements are relatively low. I still use 16 wires for the Y Axis stepper (4 wires for each stepper wire) just to be sure. I really like the idea of using ribbon cable, as it tracks so nicely without any sort of guiding mechanism. It's so very light too. It should impeded movement like a track conduit system would, and it much lighter than having an overhead cable bundle.
    I have an adjustable camera on the head, so placement can be watched via PC. Expanding to vision based feedback is something for future work.
    I have tried to create a flexible mechanical design solution. The use of angle aluminium is the basis to achieve this. If something isn't performing as I'd like, or an upgrade is desired, it's likely that only a bracket needs to be changed or modified. I have used 7.6mm polycarb where where thicker material is needed. The baseboard and the component feeder bases will be made out of corrian. It's a nice hard/stiff material that machines well, and should be nice and rigid for this application. I'm just using freebie off cuts. The frame is inch square aluminium with plastic joints. This leads to future possibilities for what is mounted underneath.
    Design Variations
    The base board defines the basic layout, which I currently show with placement area in the middle and tape strip feeders on each side. Those tape strip feeders are 8mm tapes, 16 per side. But these can be variations of other tape widths and component trays. I hope to have standard trays with most used component values, then others to cater for more specific needs. If I have a short run to place, I should have enough feeders that I can double up on components that are used more, or swap trays in/out as needed. I've also got the idea to mount reels underneath... if it's worth going to that effort of course. Including upward facing vision for component alignment is quite possible... it's just a variation of the base board to provide the real estate to mount it.
    I've spent a lot of time considering many different options. Input is welcome, however at this stage of the game I'm reluctant to make any significant modifications in order to get to first base - something that does the basics. I'm mostly into construction/build mode, modifying the design to suit build/machining requirement. Please keep in mind how small this machine is and it's intent. Aiming for design elegance, not design overkill :-)
    I'II be machining the parts over the next couple of weeks, and will post some pictures as I go. Hope everyone finds it of interest!
    Attached Thumbnails Attached Thumbnails eclipze_pick_n_place_01.jpg   eclipze_pick_n_place_02.jpg   eclipze_pick_n_place_03.jpg   eclipze_pick_n_place_04.jpg
    eclipze_pick_n_place_05.jpg   eclipze_pick_n_place_06.jpg   eclipze_pick_n_place_07.jpg   eclipze_pick_n_place_08.jpg
    Oct 2006
    461
    Here's the first part done... the stepper to pulley coupler.
    I milled a flat spot on the 10-tooth pulley, which mates with the coupler. It's a tight press fit, and also has a set screw for good measure. The stepper shaft also has a perpendicular pin going through it, so I have a tight slot in bottom of the coupler to mate with this pin.
    There was no way I could mount this 10 tooth coupler on the 5mm stepper shaft... there wouldn't be enough metal left after machining the hole hahaa... I initially was going to have the pulley on it's own axle and bearings, then a coupler to the stepper - as you normally see. However I decided to make best use of the steppers bearings and to design a coupler to mate on the outside circumference of the pulley for a rigid solution. This was a far smaller footprint and less mechanically complex solution. Time will tell if the solution has a low enough deflection, or even if a minor angle offset with the stepper mount will suffice.
    Attached Thumbnails Attached Thumbnails Stepper_Coupler_01.jpg   Stepper_Coupler_02.jpg   Stepper_Coupler_03.jpg
    Sep 2009
    119
    Hey Eclipze-
    This looks really nice. The use of RC servos on the Z-axis is rather clever. Just keep in mind that they tend to drift over time and with temperature swings. Also the lifespan is rather limited on the cheap ones because of random gear failures and encoder wear.
    Can your design accommodate for Nema 23 motor on the Y-axis in case if Nema 17 does not cut it? Just looking at the clearance under X-axis and I think that the belt may rub there.
    Also, beware of the static electricity that may develop on the plastic parts rubbing against plastic. Like those clear covers on the feeder guides. If that is made of polycarbonate or acrylic, try to get the ESD dissipative variety if you can.
    Another observation. I think it may work just fine but I still feel uneasy about those unshielded flat cables carrying stepper voltages. The RC servos may not like the interference and the solution may be to put the stepper drivers right next to the motors. Since you are looking to use small steppers, you can find or build some really tiny driver circuits like this one here: http://www.pololu.com/catalog/product/1201. It can handle 2A and 24VDC just fine and will be able to drive Nema23 no problem.
    Regards,
    Kyryl
    Oct 2006
    461
    The X axis for me is the long axis. I assume you're looking at the belt clearance on the Y axis. It only has 2.2mm as it goes over the brown camera bracket support, which is less than I'd like. I look at machining a slot on that bracket to extend the clearance.
    The potentiometers in the servos do tend to wear out, which I'm aware of. You pay for what you get with these things. I've got some cheap GWS servos to start with, which after they die I'II replace with a good quality set. I plan to have an adjustment control via the software to control the servo offset, something that can be adjusted on the fly.
    I already have a Gecko G540 for this project, which is a 4 axis 10 step stepper controller. I need 10 bit to get the resolution I was aiming for, while relying on their mid band resonance control to get fast/smooth acceleration rapids. I'II run them at a high enough voltage to get good torque at higher speeds. I could fit a NEMA 23 for the X axis by pocketing it lower in the base board. I've actually already bought it too, a 185oz/in suited to fast RPM apps. It seemed such a big motor for the application that I was worried about it being strong it might cause damage if I hit the limits (even though I have limit switches). Picture below shows the size comparison. The NEMA 23 is on standby.
    The ribbon cable may not be good enough without shielding. It's definitely a low cost and very low movement resistance, which is why I'm keen to see if it could work. But if necessary, I have the room to put tracks in to take normal cables. Otherwise, I may need to do some filtering for the servos or try to use some thin flexible metal to adhere to the cable.
    Sep 2009
    119
    Quote Originally Posted by Eclipze View Post
    I thought it's your Y that is longer from reading your first message. Never mind, I was referring to the clearance of the belt driving the long axis but didn't think about the possibility of sinking the motor down. I'd definitely go with 23'th frame on the long one.
    Yes, look for adhesive copper foil on ebay or elsewhere. Make sure it's copper and not aluminum or nickel - you'll have to solder it to the ground. But before you do foil, see if a simple isolation of the servo conductors with ground conductors will work. Another sensitive circuit would be your video feed from the camera. It will pick up EMI like crazy unless well shielded.
    Let me know if you have troubles locating the vacuum ejector assembly. I have several collecting dust here.
    Oct 2006
    461
    I could always use the NEMA 23 and set a lower current limit... so in future I can easily up the power for more speed. Would also mean I'd have margin to tighten the carriage bearing for better lower tolerance (at the cost of friction). I'II have a look at the design tonight
    The vacuum ejector assemblies I've seen online look rather BIG. Appreciate the offer though! I'm probably more keen to see how well the mechanism I've designed will work hahaa...
    Copper adhesive foil definitely does sound an attractive solution. I hadn't decided yet if the air tube and USB camera cable would run alongside the ribbon cable, or if the video feed would also use the ribbon cable. I'm going to wait until the table is moving so I can get a better feel for how the ribbon cable and/or other cables will move before committing to an option.
    For now... the Y-Axis pulley brackets are done. Bearings are a nice press fit. I could do a better job of them a second time around, however the pulley is aligned perpendicular to the rail and should do the job nicely
    Oct 2006
    461
    The X-Axis platform and stepper motor mount is done
    Attached Thumbnails Attached Thumbnails x_axis_platform_01.jpg   x_axis_platform_02.jpg
    Apr 2005
    101
    outstanding!
    Dear Eclipze:
    Fascinating project - you must be a master machinist, with a very well equipped shop-
    quite out of my league, but I'll follow your progress closely, as there will be a lot to learn...
    About the linear guides you're using: I believe they're the ones in this catalog:
    http://www.igus.com/pdf/drylint.pdf
    right? There are 4 different sizes (15, 20, 25 & 30mm) as well as 4 different shuttle
    types: Standard, Locking, Floating Horizontally & Floating Vertically .
    Could you tell us which ones you're using, and their lengthes?
    Thanks a lot and congratulations
    Nelson
    Oct 2006
    461
    Thanks for your comments Nelson. I'm far from a master machinest though. I've had a small CNC for two years, and still have quite a lot to learn. It hasn't been until recently that I've learnt enough to take on this project.
    I am using the Drylin T Series rails.
    X-Axis (long one)
    Drylin T Linear Guide, TS-01-15-600
    Drylin T Linear Carriage, TW-01-15
    Y-Axis
    Drylin T Linear Guide, TS-04-15-300
    Drylin T Linear Carriage, TW-04-15
    Z-Axis
    Drylin T Linear Guide, TS-04-12-300 (two lengths cut 68mm long)
    Drylin T Linear Carriage, TW-04-12
    All carriages are fixed bearing type, not floating.
    The big X-Axis carriage has adjustment control. The Y-Axis is a great fit. I am rather unimpressed with the small Z-Axis carriage though, an unacceptable sloppy fit. Only have one of those to start with. I've removed the bearing surfaces and plan to tap eight set screws in place to give the needed fine adjustment tuning.
    scsi... you've convinced me to change to the NEMA 23 for the X. It's big and insanely fast... gave it a test run on the bench with no load. If the belts could handle it, I could see it traversing the board from start to stop well within a fraction of a second :devious:
    May 2006
    2420
    This looks good...I am in to see how it goes
    Russell.
    Aug 2005
    1092
    An interesting design, but I can't see how you won't get bouncing of the head at the unsupported end of the Y axis.
    The faster it moves the more momentum you have to deal with. When you stop the head, the energy needs to be dissipated some how.
    I guess time will tell.
    Cheers,
    Peter.
    Homann Designs - http://www.homanndesigns.com/store
    Sep 2004
    1207
    Nice work Eclipse! I think the design has many great ideas.
    However, I'm bit suspicious about accuracy of Drylin combined with stepper and belt drive. All of them are quite inaccurate devices in some circumstances. You may end up having only 0.5 mm accuracy. I woud use at least some preloaded ball rails and servos to get within 0.1mm. Also speed can be much higher with servo as you can push it to limits without worrying losing steps.
    I'm also starting to design a pick'n'place machine at my work. Instead of SMD it will be handing unmounted laser chips and doing automated testing on them. It has great accuracy requirements but speed is less critical. It will use machine vision to pick-up parts precisely.
    Oct 2006
    461
    I wanted to make sure I had a step resolution close to 0.01mm, but the actual repeatable accuracy is certainly more difficult to put a number on. I've be very happy with 0.1mm. If it was 0.5mm, I think I'd be pushing it to place 0805 reliably. TSSOP packages with 0.5mm pitch would need operator assisted adjustment/release... come to think of it, that would be needed for SOIC's too. I'II be tweaking/tightening the carriages up before I accepted 0.5mm hahaa...
    The rails/carriages are overkill with respect to the load they carry. Keeping the weight of the head assembly low will hopefully contribute to the overall accuracy and speed. The Y-Axis rail is quite stiff with respect to the load, and with the weight of the head assembly being low I'm not concerned about it bobbing around under acceleration forces. If there is bobbing, I would be more suspicious about the flex in the baseboard first. However the design is for prototyping and pre-production, where speed isn't as important. I'd be more than happy to get around 500..800cph. But have no expectation of hitting 4000-5000cph compared to a production loader. Servos are expensive, and for such a small design these steppers (particularly that massive NEMA23 on the X-axis now!) is more than ample to move the load quickly.
    The X-Axis belt plates are done! The belt is going to be cut to length and both end secured at the carriage. The belt ends will loop up through the hole (as shown in post #7) and retained by the mating track in the plate on the top. So they cannot slip out with use.
    This top plate with the fine pitch tracks was a pre-test to make sure it was a good fit before trying to the same with the Y-Axis carriage. It's a good fit too, very happy. The depth of that track still leaves the belt slightly higher, so I have some compression when it's bolted in place. I also made the track wider than needed, so I had some sideways adjustment and also because the square edges of the tracks won't butt up nicely to the pockets machined with a round end mill tool.
    The plate that sits underneath has two purposes. The first is to hold the belt nice and straight, pointing the belt at the pulleys. The second is the vertical part is going to be used for the opto-switches that will be mounted on the baseboard. This plate will pass through those at the limit of the travel (limit switches).
    Now I know the track profile is good... next is the Y-Axis platform bracket.
    Attached Thumbnails Attached Thumbnails x_axis_belt_plates_01.jpg   x_axis_belt_plates_02.jpg   x_axis_belt_plates_03.jpg
    Sep 2009
    119
    I think we are misusing the term accuracy here. This particular machine does not have to be accurate or precise (within reason) but repeatability is paramount for the basic PnP functions. The thing will be traveling from point A to point B and it does not really matter how straight and true that motion is. What is important is that the business end hits the destination coordinates every time within 0.1mm. Does not have to be linear motion either - it's just cutting air so to speak.
    I'm saying all this assuming that the machine that Eclipze is building will have some teaching function when you can define those points A and B manually for every part. Typically they use down looking camera with crosshair.
    On the other hand, the industrial machines must be more or less accurate as they rely on motion linearity a lot. While many machines have manual teaching, the destination point of every placement motion is getting calculated by the computer based on the fiducial correction and part position correction factors.
    I don't think Eclipze is going after fiducials with this machine or going to calculate the coordinates on the fly for every part. With this in mind, I'd suggest you target repeatability and not precision of the steppers. In other words, there is no reason to use 10x microstepping trying to get 0.01mm positioning precision if you cannot repeatably position the machine due to sloppy bearings, belts or weather fluctuations. Keep in mind that with high microstepping rates your torque reduces dramatically and the step loss probability increases. Try it with 1x or 2x stepping and see if repeatability is there. If it's not, solve that problem first and then go after higher precision.
    For reference, on my machine I was playing with stepping parameters and ended up using 0.02mm/step and doing it throug "macrostepping" if there is such a term. Essentially, the servo drive has software gearing function when it can subdivide incoming step/dir pulses (microstepping) or it can multiply them. In my case I'm using 200x *multiplication* because the native travel distance of the linear servos is 100nm/step and that's a little bit too precise. That's nanometers...
    -scsi
    Oct 2006
    46
    ...The X and Y are using NEMA 17 motors... All are bipolar 1.8 degree step.
    ...2.5mm pitch, 6mm wide belts... 10-tooth pulley...
    You will receive repeatable resolution worse than 2.5*10/400=0.0625 mm, not 0.0125mm.
    But, IMO, this is suitable for 0805.
    I've tested automatic fiducial recognition with webcam and calculation the coordinates on the fly.
    Webcam was mounted on the old pen plotter. Movement resolution was about 0,1 mm (half step).
    SMD footprints was 1206.
    Webcam movements imitate:
    - movement to nozzle changer
    - movement to feeder
    - movement to place point
    [ame="http://www.youtube.com/watch?v=JIJinWAhytc"]YouTube- auto2.avi[/ame]
    Sep 2009
    119
    Atlab - that fiducial hunting video is awesome! Nice work! Can you operate two webcams in Windows?
    privet,
    scsi
    Sep 2004
    1207
    Just for reference: some Yamaha high end ball rail + servo linear axis specify repeatability of +/-0.04 mm. And that is only repeatability, the accuracy is different topic and its added to repeatability error. So the total end point position will probably have larger error than +/-0.04 mm, maybe twice of that. From that I think its difficult to get even +/- 0.1 mm with drylin + stepper.
    Very impressive video atlab! Did you use some library for feature recognition?
    BTW, where do you get cost efficient cameras with suitable optics? What are the camers in Eclipze's and atlab's systems?
    Oct 2006
    461
    I'm not that keen to have a teaching mode. I'd rather write something to translate the pick'n'place generate generated by Protel to suitable GCODE. I'm going look at Mach3 for the actual PC software, as it seems quite a flexible tool and a combination of macros and the generated GCODE may provide a usable solution.
    The stepper drivers are the Gecko G540. These are spectacular, and ramp from 10-bit stepping through to full step at speed, very smoothly.
    atlab, I'm unsure as to your calculation of "2.5*10/400=0.0625 mm". The steppers are 1.8 degree, or 200 steps per revolution and the stepper driver is 10-bit. So I understand it to be 2.5*10/(200*10) = 0.0125mm. I will be able to test this when I have the Y-axis running.
    For machine vision, it's really not something I've put much thought into yet. Always considered it more of an upgrade. It's also likely to be expensive... so I'II wait until the machine actually works before spending too much I have a webcam in the design to watch the point of placement at an angle, although I could mount this camera perpendicular to face the PCB. This would probably be more beneficial for assessing the performance. Either way... vision correction is definitely of interest!!!
    Machined the Y-Axis Platform
    Attached Thumbnails Attached Thumbnails y_axis_platform_01.jpg   y_axis_platform_02.jpg   y_axis_platform_03.jpg   y_axis_platform_04.jpg
    Oct 2006
    461
    Added index pin sleeve and mounted the platform... I'm going to change this to a plastic sleeve, but need to shave a fraction off the holes before I can fit it.
    Attached Thumbnails Attached Thumbnails index_pin_lower_plate.jpg   y_axis_platform_05.jpg   y_axis_platform_06.jpg
    Oct 2006
    46
    Quote Originally Posted by scsi View Post
    Atlab - Can you operate two webcams in Windows?
    Hello (privet) scsi!
    Yes i can with MS DirectShow, but i had some troubles with webcam selection, picture size and image buffer.
    USB passband is touble too.
    So, in fiducial recognition i used more simple MS "avicap32.dll" and WinAPI, but avicap32.dll can operate with one webcam only.
    You can experiment too: try my little prog (DirectShow) in attacment. Click by left mouse button on required small webcam picture.
    Quote Originally Posted by Xerxes
    atlab, did you use some library for feature recognition?
    No. I spent much time solving tasks of chip angle/position correction and fiducial recognition.
    I used inexpensive (US$ 20-25) webcam "Chicony 5136" (Panda 8D) 640*480@30fps.
    Optics quality isn't very crucial issue (IMO).
    Attached Files Attached Files
Page 1 of 37 12311
  1. Newbie - To build or not to build Router/Plasma Table
    By dfranks in forum Waterjet General Topics
    Last Post: 04-08-2011, 05:16 AM
  2. NEW BUILD: PVC as a build material
    By Smiler in forum DIY CNC Router Table Machines
    Last Post: 11-13-2009, 11:57 PM
  3. New Large Table Build in Houston, TX (Build Log)
    By anitel in forum Plasma, EDM / Other similar machine Project Log
    Last Post: 12-30-2008, 09:45 AM
  4. Replies: 4
    Last Post: 08-16-2005, 11:46 PM
