585,759 active members*
3,910 visitors online*
Results 1 to 10 of 10
    Jul 2005
    179
    Bridgeport DNC
    Hi All,
    Does anyone have a cable schematic to connect a Bp w/Heidenhain TNC145 to a computer and the flow control settings. I've got info from Heidenhain, Tncremont, DNC, i-logic, and generic software and the cables are all different. My control has the 25 pin connector that went to a remote tape drive and floppy. My serial port is set up COM1 2400 baud 7 bit even parity 2 stop bits w/handshake and FIFO is turned off. My last attempt was with a cable wired from PC to CNC: 2-2; 3-3; 4-6 (with pc pin1 jumped to 4); 5-7; 6-20 (with cnc pin 20 jumped to 8); 7-5; 8-4
    I checked ac voltages and I am getting signal from machine and pc on correct pins. I did get 2 errors last night on the control but they are hard to read on my screen. I think they said wrong signal and in/out not ready. Any ideas?
    HMC710
    Jan 2008
    17
    BPT Heidenhain Cable Wiring
    I wire up the cable like this
    25 pin connector
    Heidenhain ______ Computer
    2 ____________ 2
    3 ___________ 3
    7 ____________ 7
    jumper __________ jumper
    4-5 ____________4-5
    6-8-20 _______ 6-8-20
    9 pin connector
    2 _____________ 2
    3 _____________ 3
    jumper _________ jumper
    4-5 _________ 7-8
    6-8-20 ________ 1-4-6
    I made one two weeks ago
    and it worked the first time I tried it
    Rich
    www.archcity.net
    Jul 2005
    179
    BP cable
    Thanks Rich,
    Did you mean 5-7 on the 9-25 pin cable?
    What program are you using?
    Tim
    Jul 2005
    179
    Trasmitted
    Just got BP to transmit to DNCprecision but with errors. Using full handshake cable. Tncremont would not give a response. Closer....
    Jan 2008
    17
    Quote Originally Posted by hmc710 View Post
    Yes, your right 5-7 on the 9 to 25 pin configuration
    I forgot that. That's ground.
    Check under the MOD key that you have the right
    Baud Rate, Heidenhain likes 2400, and look at
    the one setting it should be RS232 not FE.
    You can use the Utility program from
    Heidenhain's website. It works. I've used it before
    Just download it from there. Good luck
    Rich
    www.archcity.net
    Jul 2005
    179
    Utility
    Will check into utility program, thanks.
    Jul 2005
    179
    TNC145 to pc
    Still have not found out where I am going wrong yet. I'll check my machine parameters today. Have the post processor on Bobcad V21, but still can't receive from the mill. I've got a 600+ line program on there and I sure don't want to have to punch it in by hand again....
    1121
    when I ran a 145 I used hyperterminal in windows to upload and download.
    2400 baud
    no flow control
    even parity
    one stop bit
    check ascii setup, <CR> etc need to be set right
    the tnc is fussier than the pc so make sure it goes both ways.
    Jul 2005
    179
    BP to PC
    Thanks for the reply Gus, I appreciate it! I was in my machine parameter this weekend and MP76 is Program End Character and it is set at 3 which my manual says is ETX.
    I am also using different parameters than you have listed; full handshake & 2 stop bits. The one picture that is in the manual has a 25 - 25 pin cable configuration with the old style 2-3 & 7-7 cable config, but it also has no handshake which I will give a try.
    I'm not exactly sure how to make sure my ascii set up is right. The manuals say CR LF ETX and then shows the coorisponding values, 13, 10, 3. Do I just start my program with 13, 10 (CR, LF)?
    Thanks for all your help out there!
    Jul 2005
    179
    Connection!
    Woo Hoo! Just received data from TNC145 to Bobcad V21. 992 lines of code! Thanks to everyone who helped out with this. Now that I have my program saved its time to start playing. Thanks again for all the help, I really appreciate it.
  1. Bridgeport 760-20
    By Richmaj in forum Uncategorised MetalWorking Machines
    Last Post: 08-24-2009, 08:21 PM
  2. Bridgeport INT 412
    By Jurek in forum Want To Buy...Need help!
    Last Post: 04-07-2009, 04:35 AM
  3. bridgeport with 151
    By bbrreid in forum Bridgeport / Hardinge Mills
    Last Post: 11-03-2008, 11:35 AM
  4. Bridgeport Needs Air?
    By JQ_Quint in forum Bridgeport / Hardinge Mills
    Last Post: 10-25-2008, 09:46 AM
  5. which bridgeport
    By james12s in forum Bridgeport / Hardinge Mills
    Last Post: 06-22-2007, 02:29 AM
