585,759 active members*
4,113 visitors online*
IndustryArena Forum > CAM Software > Uncategorised CAM Discussion > Corel Draw HPGL wrong scale in KCam
Results 1 to 9 of 9
    Jul 2005
    88
    Hello
    I set up the steps per mm all perfect and when I move the machine 100 mm it moves 100 mm exactly and when I draw dxf and mill it by the machine it does it exactly. But when I import plt files with the same settings in KCam it becomes very small in KCam.
    I am sure the table setup is perfect because it works fine with the jogging and with the dxf files, so why is this problem being with plt files?
    Thanks in advance.
    Feb 2005
    52
    I guess I would have to say that you have to make your working in MM in both programs.
    Most the time when that happens your machine is in MM and corel draw is outputting in inches. change unit in corel to match machine and also while saving in plt format make sure it isn't changing units while saving.
    Jul 2005
    88
    Thanks friend but it is in mm in both Corel and KCam.
    Feb 2005
    52
    ok as you start to save a plt file in corel draw a popup opens up and in the advanced options you still have the ability to change from inches to mm. I guess if i were checking everything I would check all options as i was saving in case even though you were working in mm the options at the time of saving may be in inches. I work with corel draw alot but I bring it into deskcnc -the cam part of it and even though I work in inchs I have to scale it down "alot" because it apparently is loaded in mm. with just kcam you don't have that step to make any adjustments.--I guess just something else to check.
    Jul 2005
    88
    Thanks ljd10 for help I will check more carefully and post feedback.
    Jul 2005
    88
    Thanks ljd10 I will check everything carefully and post feedback. Thanks again
    Jul 2005
    88
    Thanks ljd10 for your help. I will check everything carefully and post feedback.
    Apr 2005
    3634
    Can you post an example file from your CorelDraw?
    Free DXF - vectorink.com
    Jul 2005
    88
    Thanks everybody
    I scaled everything using "cnvrt metric" and everything works fine now
  1. Corel draw
    By medicsteele in forum Laser Engraving / Cutting Machine General Topics
    Last Post: 06-13-2009, 05:15 PM
  2. kcam corel
    By porn in forum Uncategorised CAD Discussion
    Last Post: 03-10-2009, 09:16 PM
  3. Corel Draw 12
    By millman52 in forum Uncategorised CAD Discussion
    Last Post: 11-18-2008, 05:24 AM
  4. kcam HPGL DXF result
    By Isaak in forum Uncategorised CAM Discussion
    Last Post: 04-27-2008, 06:29 PM
  5. Where to get Corel Draw?
    By WarrenW in forum Uncategorised CAM Discussion
    Last Post: 12-29-2005, 10:07 AM
