585,758 active members*
4,675 visitors online*
Results 1 to 8 of 8
    Feb 2006
    40
    Consumer Reports for EMC2
    This post is (I Hope) for people to weigh-in on what components would make the best CNC MACHINING CENTER (VMC 20-40 amp motors) you can build and still fit in the garage. There are countless combination's of parts, controller cards, drives, encoders 200-2000ppr,servo motors, etc that you can use. The last factor I want to impose here is COST! Biggest Bang for the Buck! If something works just as good and costs less it wins. So let me guess the winners just to get things going:
    I personally am ruling out AC Servo for bang for buck reasons and other items too since we are all on a budget but nobody wants junk when they are done.
    Controller card- 1st- Mesa 5i20
    2nd- Pico universal PWM
    Drives- 1st- Servo Dynamics type that came with machine
    2nd- Pico PWM amplifier
    3rd- Larkin Viper 200 with Pico "Gecko Interface" card.
    Encoders- 1st-1000ppr USDigital
    2nd- What came on machine 500ppr.
    Servo Motors- 1st- What cam on machine if good.
    2nd- Used SEM, Baldor,etc you can find cheap.
    This is all the high ticket parts I can come up with that will eat up your budget and I don't know that much about electronics to evaluate but I do know cnc milling and what happens if you choose poorly... .
    Feb 2006
    40
    Oops! I forgot the VFD (Variable Frequency Drive) for the spindle. No self respecting system can be without one of these.
    1st- Any Flux Vector model $$$ with spindle orient for tool changer.
    2nd- Any Sensorless Vector model. Rigid Tapping but no spindle orient available.
    Mar 2004
    369
    Quote Originally Posted by greeder88 View Post
    Hate to keep blowing my own horn, but the Pico PWM controller has more things included
    in it, that you have to pay extra for on the Mesa boards. So, it considerably narrows the
    cost in most applications.
    I have recently tried the Cui AMT102 encoder that is available for about $29 from Digi-Key, and they seem to work well. It looks like they should be able to fit on a number of motors. They go to 2048 cycles/rev, you surely won't find another new encoder that cheap with that resolution.
    There was a time servo motors went relatively cheap on eBay, now they are flooded with
    brokers selling used motors for thousands of $. There is still occasionally a bargain, but they are harder to find. Keling has some very nice motors that go QUITE cheaply. I have tried their size 23 motor for $56, they also have a size 34 motor a little over $100. These need encoders added, the Cui fits nicely. IMTT USA has a quite awesome 80 mm motor for $135 I think, but it is a lot harder to put an encoder on it. If your install can use an encoder on the end of the leadscrew, this is a good source.
    Jon
    Jon
    Feb 2006
    40
    Anyone have experience with different servo drives? Drives run from very cheap to really expensive. What do you get for your money?
    Feb 2007
    54
    greeder,
    why would you go with a PWM controller over a PPMC? It was my understanding that you would have a little more choice as far as components goes with PPMC than PWM....and it seems the accumulated cost of components is what gets yo uin the end..
    Do I have this wrong?
    Mar 2004
    369
    Quote Originally Posted by roger_e View Post
    greeder,
    The PPMC is an analog interface to velocity servo amps, and the basic set is $780.
    You still have to come up with a set of velocity servo amps.
    The Pico Systems PWM controller is $250, and Pico Systems brush servo amps are $125
    per axis. The brushless servo amps are $150 per axis. So, you can get the PWM controller and
    3 brush motor amps for less than just the PPMC interface boards alone.
    If you want the performance or other features of a velocity servo amp, then the PPMC is a good choice. If you just want a cheap servo system, the PWM controller and amps are cheaper.
    The PWM system needs fairly high resolution encoders to run smoothly, as it lacks the velocity feedback inherent in a velocity servo system. If you will be using low resolution encoders, the performance may not be acceptable. That's where a velocity servo shines, making a system with low-res encoders still run smoothly.
    Jon
    Feb 2006
    40
    What do you mean by "performance or other features"? Compare the two systems assuming you buy 1000ppr encoders ($75.00/axis) for both systems.
    Mar 2004
    369
    A true velocity servo amp is what is called a "continuous-time system", so that it doesn't have
    to wait for the encoder to cross over to a new count to sense movement. Using only an encoder for velocity sensing, it is impossible to detect movement until the encoder hops from one count to the next. So, the servo loop is essentially running open loop until the count occurs. With a DC tachometer sensing the velocity and feeding it back to the velocity error amplifier, it is possible to constantly monitor velocity even between encoder counts. I did some tests while working on my own velocity servo amps about a decade ago, and was able to have totally smooth motion from 100 IPM down to 0.01 IPM, at which point the stick-slip friction finally overcame the finite gain of the system, and movement started to get slightly lumpy. This is a 10,000 : 1 velocity ratio! The encoder was providing about 3 counts per second at this rate. Without the tachometer feedback, it would be impossible for a servo to maintain smooth velocity with only 3 position updates a second. I couldn't measure it, but the DC tachs were calculated to be providing 7 micro-volts of output while moving at 0.01 IPM.
    You may wonder why I'm worrying over performance at 0.01 IPM, but when boring circles or cutting angles close to one axis, the other axis may be required to move extremely slowly. You don't want to have steps there, or you might as well use a stepper motor.
    This was with 1000 cycle/rev encoders directly mounted on the end of the ballscrews.
    This is why some control vendors now supply insane encoder resolutions on their systems, to
    provide velocity feedback.
    Jon
  1. EMC2 HELP HELP HELP
    By Alwyn in forum OpenSource Software
    Last Post: 10-11-2008, 05:18 PM
  2. emc 2.2.2 bug reports ?
    By Gads in forum LinuxCNC (formerly EMC2)
    Last Post: 02-14-2008, 03:39 PM
  3. Inspection reports
    By 1947Hack in forum Calibration / Measurement
    Last Post: 01-16-2008, 01:59 PM
  4. SmartCam custom Job reports
    By Independent CNC in forum CNC (Mill / Lathe) Control Software (NC)
    Last Post: 11-10-2006, 03:43 AM
  5. Do you like Wallcrawler weird news reports?
    By WallCrawler in forum Community Club House
    Last Post: 04-21-2004, 01:12 AM
