I purchased a 110 G a few months back, I have finally been able to get power to it. The excitement has quickly turned to grief. I am hooked up to three phase, reason for delay in getting power.
The battery died. When turned on power to the unit there is a delay, then the cooling fans turn on, and the Power on led turns red. I have several led's lit up inside the cabinet, but that is all that happens. Screen does not turn on. When I push system ready button nothing happens. Pushing buttons nothing happens other than the beep. Here is the kicker, when I push and hold the power off button it shuts down but as soon as I release the power off button the fans and leds start back up. One other thing, the dirty water pump has turned on and shut down two different times, cannot tell you why.
I am on three phase with a wild leg. I have swapped wires to make sure phase wasn't reversed, no difference.
Any direction where to start would be very appreciated.
