585,764 active members*
4,571 visitors online*
Results 1 to 6 of 6
    Feb 2009
    1290
    Universal motor controller
    I have been looking for some way to control my PC 9690LR router and I ran across this article.
    http://www.siliconchip.com.au/cms/A_111129/article.html
    It is written for 230VAC mains and I was wondering if it would work on 110VAC mains? I have not seen the whole article as I would need to pay for it.
    24220
    You should be able to get plenty of Triac control circuits out there, many by Component manuf.
    http://www.educypedia.be/electronics...torcontrol.htm
    There is one included here around the TDA1085 which if you put a simple pulse detector on the motor you have accurate speed control.
    Al.
    Albert E.
    Feb 2009
    1290
    I have been looking for a complete circuit based on the TDA1085 but I'm unable to find one with all values marked.
    24220
    http://www.onsemi.com/pub_link/Colla...TDA1085C-D.PDF
    I have one from a T.M. motor circuit I could PDF.
    Al.
    Albert E.
    Feb 2009
    1290
    Thanks for the help Al. I'm interested in the TDA1085 but I would have to figure out a way to add a tacho generator to my PC router which may not be easy.
    Feb 2009
    1290
    I ended up purchasing a C29 board from CNC4PC.
    The C29 is just the board with connectors you supply the case. I used an old PC power supply shell, not a standard ATX power supply. I hooked an 5k pot to the analog inputs and tested the unit with my hand drill. It works as advertized, once I get the mount for my Porter Cable made I will hook it up to Mach3.
    Attached Thumbnails Attached Thumbnails DSCF0001.JPG   DSCF0002.JPG   DSCF0003.JPG
  1. PWM drive for a 2KW universal motor/router
    By LZ1TWB in forum CNC Machine Related Electronics
    Last Post: 12-11-2011, 11:12 PM
  2. Looking for AC universal motor driver circuit scheme
    By bedo in forum DIY CNC Router Table Machines
    Last Post: 08-17-2008, 09:33 PM
  3. D.C motor controller
    By swarfmacdaddy in forum CNC Machine Related Electronics
    Last Post: 08-02-2007, 06:28 PM
  4. dc series universal motor
    By jed102 in forum Servo Motors / Drives
    Last Post: 05-03-2007, 03:09 AM
  5. "Universal" AC/DC motor
    By Swede in forum CNC Machine Related Electronics
    Last Post: 02-17-2004, 09:16 PM
