585,981 active members*
4,470 visitors online*
    Sep 2007
    356
    DRO doesn't equal Movement
    I just installed a new BOB and G203Vs on my BP. When I move the table or quill in any direction the DRO reads more than the actual movement. I've made sure that I am in inches. My steps are the same as before I made the conversion (1000 steps). I'm pretty much at a loss as to what to look at next. Thanks, Ron
    Is the actual movement correct? If not, you're steps per unit is wrong.
    Sep 2007
    356
    I didn't realize G203Vs are 10x micro stepping, also I have my motors wired half step. I haven't measured the movement yet, but I think I'm close.
    Jan 2010
    9
    Definitely make sure that you microstepping is factored in correctly to you calculation. I had the same problem. I use a Gecko G540. Multiply TPI*(microsteps per step)*(steps per revolution)*(revolutions per inch)= steps per inch. In most cases, the steps per revolution is 200. For my machine, my total steps per inch is set at 4000. (10 TPI)*(10)*(200)*(2)=4000. You probably already used this formula, but in case you didn't, there it is.
  1. All high-flex cables are not created equal
    By igus in forum News Announcements
    Last Post: 05-11-2009, 03:12 PM
  2. Help with equal spacing
    By MegaMoog in forum EdgeCam
    Last Post: 06-03-2007, 02:45 PM
  3. G54 and tool offsets to be equal
    By Jedi in forum Mastercam
    Last Post: 05-17-2007, 04:34 PM
  4. Are all riser blocks created equal.......
    By jstarnes in forum Bridgeport / Hardinge Mills
    Last Post: 02-01-2007, 10:27 PM
  5. How Does One Get the Machine Scale to Equal Mach2'
    By TheNigerian in forum Machines running Mach Software
    Last Post: 05-08-2006, 09:03 AM
