585,996 active members*
4,504 visitors online*
IndustryArena Forum > MetalWorking Machines > Fadal > Keeping Coolant Clean?
Results 1 to 17 of 17
    Oct 2006
    143
    I'd like to revisit this subject, I've seen a few suggestions of how some of you are doing this scattered about. Can we put it all in one thread?
    What you use?
    Applicable part #'s and source?
    Don
    Jan 2007
    1389
    you can buy one or make one. I have gone through 6 of them store bought in 15 years. Finally said screw it and used a rotisserie motor with the org disc and frame works perfect.
    The motors go bad but usually its the gears inside that go bad. so I ended up using rotisserie motors.
    BTW its just angle Iron to make one also
    Jul 2005
    12177
    Do you mean removing tramp oil?
    I am a recent convert to coalescers. I did try skimmers but they could not be fittied on most machines and when they could be put in place they tended to take out coolant as well as tramp oil. Also it was necessary to have the coolant sitting still for over a day to get the tramp oil floating to the surface so the skimmer could get it; skimmers are not effective when the machine is in use.
    Coalescers work whether the machine is circulationg coolant or not, although they can be more efficient when the coolant is not circulating. In these the coolant is pumped through a coalescing filter which is a stack of finely grooved plastic discs, into a holding tank. The tramp oil dispersed in the coolant tends to adhere to the plastic and comes out of the filter as micro droplets which float upward in the holding tank while the coolant is returned to the machine from the bottom of the holding tank.
    EDIT: I just noticed: Part numbers and source? Keller Products, I forget the part number but we ordered the largest size individual machine units; the one I bought first for testing was the small size portable unit.
    I bought a coalescer at half price a few months ago as a test on my home shop machine which had really grungy brown colored 18 month old coolant that developed a skin of tramp oil about 1/8" deep wheneever the machine was not running for a week or so. It took about four weeks of running the coalescer fulltime and the coolant became a creamy white color and there was about 1/2 gallon of tramp oil in the holding tank of the coalescer.
    That was so encouraging that at our Christmas cleanup we collected the coolant from all the machines in a 300 gallon tank and instead of getting a disposal company to take it away as we did previous year, we connected the coalescer; I had to monitor it because for the first three days so much oil was being collected it was overflowing the holding tank on the coalescer. Over the eleven days of shutdown the coalescer removed about ten gallons of tramp oil and we returned nice creamy white sweet smelling coolant to the machines when we started up again in January.
    Then we ordered fifteen individual machine coalescers so we can keep the coolant clean all the time.
    Jun 2008
    230
    Geof,
    That was great development. Any chance to see pictures, connected to machine, opened unit to see the guts, connection scheme?
    What about UV light or UV filter sets to kill bacteria with, that many talks about? Anyone with experiences?
    Darn!, I just built my own skimmer, mostly from parts I had laying around.(chair)
    Anyway FWIW, my DIY way oil skimmer:
    Completed chassis 1,5 mm steel sheetmetal, easy to weld.
    The skimming strips are made of 0,8 mm Teflon, I had laying around, with 3mm steel hold-down strips fastened with 4mm countersunk screws.
    I also had this 230VAC geared motor, unfortunately only 2rpm, so I will have to run it for longer periods during nights. The oil will defenitively have time to adhere to the disc LOL. Turned a simple alu housing to protect it.
    I also had this 10 x 26 x 8 mm 2RS ball bearing, so I made a housing for that too.
    The shaft is made of stainless steel and I had to make it 3-part, so I could slide it in place complete with the disc on it when the skimmer frame is under the machine, on top of the tank. The joins are just usual "jam" pipe joins from the plumbers' industry.
    The complete ”moving parts kit”. The disc is made of 3,2 mm Acrylic(plexiglas) with a 300mm dia. Flashy color? This is what I had, why not use it?
    Mock-up for testing it before the paint came on. The disk runs very lightly between the teflon lips, even when running it dry. The measured power consumption is only 4W!
    This is how it will sit on the coolant tank.
    I applied 3mm self adhesive and oil resistant cell rubber strips to cushion against the tank so it stays put.
    When installed, the disc runs 25mm above tank floor.
    A houshold plastic container acts as my catch tank. A see-through version is preferable, to see when it is getting full. The skimmer is run via an electronic household timer for some hours duty during nights.
    To be honest I have not tried it yet, but my first machining will soon take place, and then I will report on the performance.
    I have also installed a fish tank aerator to keep the coolant aerated (bacteria hate it). Pics and story next time.
    Cheers
    Jul 2005
    12177
    Quote Originally Posted by CNC Viking View Post
    Geof,
    What about UV light or UV filter sets to kill bacteria with, that many talks about? Anyone with experiences?.........
    Before answering your question I have to ask: How do you keep your place so clean? I have been complimented about how clean our place is but cannot hold a candle to you.
    Pictures? No I didn't take any but you can see them here;
    http://www.kellerproducts.net/tramp_...ngle_pumps.htm
    They are really quite simple; a compressed air operated pump, an inlet cartridge filter, the holding tank with the coalescing filter inside and a few pipes. Actually Keller Products calls it "(the) patented Keller all-plastic
    separator element
    ", and I have to give them their due; it works better than other separator systems I have seen. The key with these separators is to give the ultra-micro-scale dispersed oil droplets a chance to contact the plastic surface. Because the oil has a higher affinity for plastic than water does it sticks to the plastic, that is how the skimmers work, the oil sticks to the plastic disc better than the coolant. Once the oil is in contact with the plastic it moves along with the flow and the really tiny droplets bump and fuse into just tiny droplets that ooze out of the end of the grooves I mentioned; then these droplets float up faster than the coolant is flowing down in the holding tank. A pre-filter is necessary of course or the grooves will get clogged with metal fines.
    Regarding UV sterilization coolant is opaque so how is the UV going to penentrate to get at the bacteria. Anyway sterilization is pointless because coolant tanks and machines are open to the air so bacterial spores are getting in all the time. Also it is not needed if you keep the tramp oil content very low and keep the coolant aerated. The bacteria that create foul smells are anaerobic and they metabolize sulfur compounds in the oil in the absence of oxygen; remover their food and keep conditions unsuitable for them and they are not a problem.
    Oct 2006
    143
    Geof,
    That is certainly a glowing review of the Keller skimmer! You should be getting a commission! I'm definitely going to investigate these.
    I had seen some suggestions for simpler filtration (pads, etc). I'd still like to hear other suggestions and what you are using.
    Don
    Jul 2005
    12177
    A long time ago I tried the pads that were supposed to soak up the tramp oil when you floated them in the tank. They did work but it was necessary to wait for the oil to float to the surface first then put them in. I think they are potentially an economical solution if your machine is used infrequently so there are long periods of time when the coolant is static and the oil can float to the top. But they are messy, oil drips everywhere when you a taking them out, and really they should not be thrown in regular garbage. When the oil is collected as oil you can take it to an oil recycling place, or as we do wait until we have a 45 gallon drum full and then get it picked up.
    I am happy to give glowing reviews when a product works for me and I don't need to be "bribed" with a commission.
    Oct 2006
    143
    Geof,
    I like what I see in that skimmer, it looks like a good product. Although it is not in the budget at the moment it may be a priority purchase in the near future. I'm glad they didn't have to bribe you, at least I know I'm getting an honest review!
    Thanks Again,
    Don
    Nov 2007
    1702
    Wow, thanks for sharing that, Geof. I've been looking for the right solution for my VF-2 and that looks like it.
    Greg
    Oct 2003
    530
    I'm tesing a zebra sidewinder skimmer.
    http://i445.photobucket.com/albums/q...idewinder1.jpg
    http://i445.photobucket.com/albums/q...idewinder2.jpg
    http://www.zebraskimmers.com/oil_ski...l_skimmer.html
    So far it works great! I got the magetic mount so I could move it easily from machine to machine.
    The reason I chose this skimmer is that it would fit every machine in my shop from our haas sl-10 and tl-1 tanks to my okuma mcv4020 and captain lathe tanks. The coolant does need time for the oil to build up on the surface then you skim it out. If you leave the skimmer on after it's removed all the oil it will remove some coolant. Usually it only needs to run for an hour or two then I move it to a different machine.
    I used to use a keller filter, but I wasn't satisfied with the results. the unit itself is a pita to clean and if you leave it sit for a while the air pump will get stuck. This happened a few times and I had to blow compressed air through the exhaust muffler on the air pump to free it. The skimmer is a better solution in my opinion. It's also much cheaper than the keller filter.
    BTW, CNC Viking that is a bad@ss skimmer!!! You definatly have one of the best skimmers I've seen
    Oct 2006
    143
    Edster,
    Thanks for the response. A friend of mine just mentioned the Zebra skimmer to me yesterday. You didn't like the Keller, how long did you use it? How long have you used the Zebra? How does the Zebra work? There is not a real clear description about installation and how it picks up the coolant/oil to separate it. Can you give a rough $$$ amount?
    Don
    Ah, I found a picture that shows how it works.
    http://www.oilskimmerstories.com/sto...arkmfctng.html
    Jan 2004
    3154
    The UV systems and other methods of killing bacteria generally are a poor choice. To keep the coolant as it should be, it needs good bacteria, these will die with UV as well.
    My machines don't get used enough for a system such as the Keller. Both for money reasons and that they will completely clog while sitting idle for extended periods.
    I hated the skimmer/soaker bags as they soaked up the "imulsified" coolant oil as well, creating 2 issues.
    1) The bag was saturated (therefore useless) in a couple of hours.
    2) The coolant concentration had to be continually checked and adjusted (to no avail due to the bags).
    My current mixed bag-o-tricks.
    Every machine has a Zebra skimmer - the disc units are better but I have Sidewinders on the machines that the disc wouldn't fit. My skimmers are all on timers or operated by the MCS. The first morning you come to work when you accidentally left the skimmer on all night you will know why.
    I have a bubbler system hooked up to the compresser at 5PSI with soft cooper runners in my tanks. Runs 20min on every hour.
    I put filter paper on all the return baskets to catch any fines.
    Get a refractometer and keep the concentration levels at optimum.
    These things have prolonged MY coolant life ten fold.
    www.integratedmechanical.ca
    Oct 2006
    143
    DareBee,
    Do you think the disk skimmer works better on your Fadal than the sidewinder would? I have a disk skimmer on mine but it seems to take more coolant out 20/1 for oil. It's frustrating because than I have to skim my drip pan.
    Don
    Jan 2004
    3154
    Hey Don
    I would say my tramp bucket is about 50/50. But at the end of the day; 3/4 liter of way lube and coolant froth and 3/4 liter of coolant going into the waste drum is of no cause for concern on my part.
    Generally speaking I usually only skim while machining and the coolant is agitated. I believe that the coolant slightly separates when standing still and you will remove more of the "good" stuff in that scenario. I have the skimmer plugged into the switched "mist" receptacle so I can turn it on in my program or by a press of the Coolant B button.
    The Sidewinder on my lathe probably on picks up half the amount of coolant as it does tramp but it is nowhere near as effective at removing the tramp. It all boils down to surface area.
    Jun 2008
    230
    Fish tank bubbler
    Edster wrote;
    BTW, CNC Viking that is a bad@ss skimmer!!! You definatly have one of the best skimmers I've seen.
    Thanks for the comments guys!:cheers:
    Geof, wait till I really use it to produce parts. I guess It will catch up soon. Still, I believe that a clean and looked after machine will reward me in the end. No way, that I will let her go back to the state she was in when I purchased her.
    I have a thread about her here: http://www.cnczone.com/forums/showth...836#post725836
    In the light of Edster's and DareBee's experiences, I think I will hold the trigger on a Keller unit for the time being.
    DareBee, so you say that one should skim while machining. I was thinking on skimming a couple of hours during nights and the same with the fish tank bubbler. What Do I set the timers to do?
    My Z-axis box ways issues quite a bit of way oil. Rather than fishing it out of my coolant tank,
    I catch it right under the box ways. The oil is cought by a small catch tray and then runs in a
    plastic hose to a small plastic container. Cheap and easy.
    What about adding course and fine filters on the outgoing coolant stream after the pump? Any added tool life from that? My system is normal flood type, not hi pressure. If yes, what gear do I need? Pictures if possible, please.
    My fish tank bubbler installation:
    I bought this dual outlet air pump kit at one of those "hobby pond" stores. Cost less than
    $40 incl. shipment and all.
    The unpacked kit. 10m silicon hose, check valves, bubbler "stones"
    and spare diaphragms for the pump. I am afraid the pump will eat those for breakfast...
    The pump consumes only 9W and is very silent. Still it delivers 540L / hour through 2 bubbler stones.
    The bubbler stones placed in each corner of my U-shaped coolant tank.
    The 230VAC pump and its timer fits nicely in the electrics cabinet.
    Jan 2004
    3154
    Containing the oil from known run off areas is very good to implement.
    Never a good idea to filter anything on the pressure side of a pump. That is asking for trouble.
    I skim while machining, a couple hours at night is good as well. I found that skimming 1st thing in the morning after the machine has sat for 16 hrs (stagnant) that I would remove concentrated coolant more so than skimming while (or shortly after) agitating.
    The timer thing - I am blowing low volume 15PSI air into 4 tanks. I am not going to get into math - but lets say my 15hp compressor runs 10min/hour to do that. That is a lot of amperage (i could buy a bunch of fish pumps and run them). So I got an ASCO RedHat hired a 3 prong plug onto it and plugged it onto a programmable hardware store timer so as to make the system more efficient (20on/40off).
    Constant aeration is likely best but you do what makes the most sense to you.
    Jan 2004
    3154
    I may have missed some of your question.
    My skimmer on the timer is like a bathroom fan timer (0-4hrs).
    When I power the lathe, crank the timer to 3 hours (whatever).
    When I go home at night and have forgotten to turn off the skimmer, I do not have an incident all over your beautifully tiled garage floor (nuts)
    The bubbler timer is just to save money.
  1. Best way to clean coolant soaked windows ?
    By kojack in forum Haas Mills
    Last Post: 05-29-2008, 09:52 PM
  2. keeping rails clean
    By HMD in forum DynaTorch
    Last Post: 10-14-2007, 12:46 AM
  3. How to clean mini mill coolant cheaply and easily?
    By 1ctoolfool in forum Haas Mills
    Last Post: 01-16-2007, 02:10 AM
  4. Question of keeping Ball Screws Clean
    By widgitmaster in forum DIY CNC Router Table Machines
    Last Post: 10-06-2005, 02:16 AM
  5. Keeping the 'puter clean
    By paulried in forum DIY CNC Router Table Machines
    Last Post: 01-01-2004, 12:30 AM
