585,997 active members*
4,844 visitors online*
IndustryArena Forum > CAM Software > GibbsCAM > Need help with Lathe Contour toolpath, please.
    Jan 2010
    I am trying to program R. R. Moore fatigue test specimens on my Hardinge SV150 CNC Lathe. The roughing passes go fine, but the contour passes are incomplete, skipping over my initial straight section and starting the contour in the profile section. Doesn't matter where I put the contour start point, the result is always the same. Can anybody tell me what I have done wrong? Thanks in advance!
    Attached Files Attached Files
    Sep 2006
    59
    I'm no Gibbs Geometry expert, but the fact that that sketch segment is red even though it is not selected bugged me.
    I right clicked it and selected Change Feature from "AIR" to "WALL" and it turned blue like the rest of the geometry. Redid the contour Op and it cut as you intended.
    Jan 2010
    Quote Originally Posted by pdoherty View Post
    Maybe not, pdoherty, but you had the knowledge I needed! THANK YOU! Now I can post it, proof it, and get on with the show. I really appreciate your help.
    Sep 2006
    59
    Glad to help. I know all too well the frustration of fighting with Gibbs.
    Dec 2006
    30
    gibbs 1987 ,,went out of buisness
    try some thing new
    and simple
    u might make a dolla or 2
  1. lathe point toolpath
    By camtd in forum Mastercam
    Last Post: 04-12-2009, 11:57 PM
  2. MC9 mill toolpath in lathe-newbie question
    By scolee in forum Mastercam
    Last Post: 08-15-2007, 10:02 PM
  3. Incomplete toolpath on closed contour
    By LongRat in forum SheetCam
    Last Post: 07-11-2007, 08:51 AM
  4. Surface contour toolpath (odd)
    By jnc in forum Mastercam
    Last Post: 04-23-2007, 01:16 AM
  5. changing mill pocket toolpath to lathe-v9
    Last Post: 03-25-2007, 03:39 PM
