hey this is probly in the wrong section, i couldnt figure out with would fit best.
but anyways can anyone recommend a spot to get some steel ive searched and im not coming up with much i need
4340 and 1050 steel billets
TIA!
TIA!
Try McMasterCarr, they have quite an assortment of materials. If you need bulk they are a little on the expensive side. We use them as I can get what I need the next day, for me getting my stock quickly is more important than saving a few bucks, and we don't need large amounts of stock. Hope this helps.
onlinemetals.com, speedymetals.com for hobby sized stuff
What size is "bigger"?
Dick Z
DZASTR
Look in the yellow pages for industrial supply, steel supply, etc. There are at least 6 suppliers in the town I work in, all having huge warehouses full of steel. Where are you located?
Matt
Has anyone purchased software called CAD-KAS FONT 2 DXF is it worth the money? Needing to find a software that can do letting for lasers, that has the letters split into or a stencil format.
Alro Steel has warehouses in Tulsa and St. Louis. I buy most of my stock through them.
www.alro.com
If that doesn't work out, you could contact Nessteel. They specialize in tool and alloy steels and ship all over the US. Shipping might be more expensive since they are in CT, but they could probably get you what you need.
http://www.nessteel.com/
Matt
It might be less expensive to purchase drop-offs from round bars and mill it to size. Many alloys are available in hot rolled rounds only.
Dick Z
DZASTR
If that is the case then onlinemetals has round bar of the appropriate size.
linky
$260
Matt
If you plan on doing close to 20/month you can get a 20' bar and have two months worth.
I wanted some 19 gauge CR steel sheet and my usual place laughed at me. I found a place called Windustrial and they got some and delivered me 5 4'x8' sheets. I looked and there is one in KC.
Hi ebydrc On doing that much a month you should be able to get some good pricing
I use Nessteel they have may have what you need
http://www.pennsylvaniasteel.com/flexor.php
Mactec54
ill have to talk to them about a year ago i talked with a forginf company, they wanted a 100 unit first off and a large fee to start a run, the rep i talked to said that was industry standard, i never checked other companies to see if there was any truth to the statement, at that point i was thinking about a new business venture, now. however id really like to pull the trigger and figure out where and what i need to do to get the material
