585,981 active members*
4,419 visitors online*
Results 1 to 8 of 8
    May 2008
    26
    Suitable router for CNC machine
    Hi all,
    Someone may beable to help. I am looking for a suitable router for my CNC machines. What I need is one with variable speed and can purchase both 6.35mm and 6mm collets. At present I'm using Makita trimmers but these are fixed speed.
    I have looked at Kress ones but these are to expensive to import. I don't want one with handles like traditional type routers. I looked at the Hitachi M12VC but can not find any 6mm collets for them.
    Does anyone know of a suitable router/trimmer(variable speed) I could use???
    Regards
    Jan 2007
    38
    What size collet is it ER?
    Noel
    Sep 2009
    30
    Hello
    The WORK or WORX brand or whatever brand it is they have at mitre 10 are a good unit have a good reputation in the UK hardly anyone here uses them not to sure on collet size.
    They are a variable speed via a control on the handle for them at $199 they are a good deal just a suggestion there are heaps of others out there to that are variable speed drive
    Thanks Nick
    May 2008
    26
    Quote Originally Posted by wildgrav View Post
    Noel
    What do you mean ??????
    Jan 2007
    38
    Feb 2010
    I guess you are just after a spindle. Try Isel Automation http://www.isel.com If they don't have an agent in NZ, Applied Automation in Melbourne sell them +613 9454 5011.
    Feb 2010
    This link is straight to their spindles http://www.iselautomation.de/product...lang=en&ID=c72
    Jun 2008
    44
    I use a Makita die grinder 1/4" collet and variable speed, See my build on
    http://www.cnczone.com/forums/showthread.php?t=64523 The grinder works great!
  1. Steppers suitable fo router?
    By jpc1431 in forum Stepper Motors / Drives
    Last Post: 03-06-2009, 05:54 AM
  2. Is this machine suitable
    By ball99 in forum Waterjet General Topics
    Last Post: 08-18-2008, 02:04 AM
  3. Replies: 2
    Last Post: 08-15-2007, 05:14 AM
  4. Hardened steel tubes, suitable for frame cnc router ?
    By vroemm in forum Mechanical Calculations/Engineering Design
    Last Post: 07-09-2007, 08:29 AM
  5. Need a suitable machine
    By Moesian in forum Mechanical Calculations/Engineering Design
    Last Post: 08-14-2005, 05:49 PM
