585,969 active members*
4,452 visitors online*
IndustryArena Forum > CNC Plasma, EDM / Waterjet Machines > PlasmaCam > Cut stops and starts along cut path.
    May 2007
    4
    I have an older PlasmaCam machine that sometimes refuses to cut areas along the cut path. I've tried retracing the path and it stops and starts cutting at the same point everytime. The torch continues to work along these points but it just does not cut. I'm running a Hypertherm torch.
    Anyone here have a clue why this happens?
    Frustrated,
    John
    Jun 2007
    50
    Are you saying that the torch is firing but not cutting through?
    Then the metal has a bad spot in it. It happens.
    Oct 2007
    14
    This has happened to me several times recently.
    In my case, it was worn consumables or blowback material stuck to the torch tip. I can usually just pass a piece of cardboard over the tip to make sure it's free of debris, back 'her up and hit the start button.
  1. Machine stops at end of tool path
    By Cellar Dweller in forum Mastercam
    Last Post: 09-29-2009, 11:14 AM
  2. M-Stops and starts
    By shane.vella in forum Machines running Mach Software
    Last Post: 09-25-2008, 07:48 PM
  3. Too many "M00"s. stops and starts
    By mike hide in forum SheetCam
    Last Post: 09-16-2008, 12:04 AM
  4. Replies: 0
    Last Post: 06-30-2007, 10:13 PM
  5. Starts
    By AZCoyote in forum Waterjet General Topics
    Last Post: 01-21-2005, 12:33 AM
