585,743 active members*
5,022 visitors online*
Results 1 to 5 of 5
    Feb 2010
    27
    I am starting to crawl
    Hey guy I am new here and will be starting a CNC Mill soon.
    I trained as a Elect Eng but love mechanical challenges.
    My goal is to build a routing mill that will make PCBs.
    I have heaps of questions. Like are the Controllers on Ebay that use the Toshiba TB6560AHQ chip worth while?
    how do I spec my PC? is a Compaq SFF 1800Mh P4 with 2G ram OK? it is probably one of the only one I own that has a Parallel port.
    I stumbled across Small Parts & Bearings. is this the only supplier of Pulleys Belts in AU?
    Cheers & Thanks
    Matt
    Jan 2007
    38
    SPB is the only one I have seen. You could use a Smooth Stepper via USB http://homanndesigns.com/store/index...ain_page=index Breakout boards etc here
    Feb 2010
    27
    Sorry for the double posting.
    MODs - feel free to delete one.
    Dec 2009
    18
    hi Kool-kites
    for belts and pulleys you could try a mob called P.I.E.S. there in melbourne
    http://www.piesau.com.au/MainFrame.htm
    they have some good quality belts
    Jun 2007
    149
    your pc will be great.
    those toshiba chips are good value, i think ebay has 3.5 amp 4 axis cards which can take 50v. (i think thats right?)
    most smaller nema 34 motors will party with that.
    but, cheap drives all suffer mid band resonance, if you know a cheap way to fix that let me know.
  1. Just starting out
    By Larry Myers in forum Laser Engraving / Cutting Machine General Topics
    Last Post: 09-20-2009, 10:08 PM
  2. Starting off...
    By viroy in forum CNC Machine Related Electronics
    Last Post: 07-07-2008, 10:27 PM
  3. Replies: 2
    Last Post: 06-30-2008, 09:54 PM
  4. starting out
    By onya in forum Australia, New Zealand Club House
    Last Post: 12-20-2007, 09:57 AM
  5. Just starting out
    By BawFlinger in forum OneCNC
    Last Post: 10-18-2006, 09:13 AM
