585,761 active members*
4,244 visitors online*
IndustryArena Forum > Machine Controllers Software and Solutions > Fanuc > Fanuc 18M on DAHLIH VMC-720 Manual/parameters needed
Results 1 to 17 of 17
    Feb 2010
    46
    Unhappy Fanuc 18M on DAHLIH VMC-720 Manual/parameters needed
    Hello!
    If anyone would be so kind to send me a parameter manual in English for Fanuc 18M or/and some basic parameter explanation/list, also would appreciate some tips for setting this machine again all memory is deleted (parameters,etc)
    so far i managed quickly to get alarms off but Z axis is inverted and has reverted work range so i can move it only few cm lol, also i dont have mem, mdi modes etc..
    Thanks in advance
    My email: [email protected]
    Jun 2008
    1511
    I will dig up the manual to send you but you need more than that. Your option parameters need to be entered. You don’t have a copy of any of them? Your best place to start is to call Fanuc and or Dahlih and give them the serial number of the machine. They should have a backup of some sort for your machine to get you going.
    Stevo
    Mar 2007
    122
    Diagnostics and options
    Since that is an old machine it won't help to contact DahLih because there file backups went missing along with their computers. If you PM me I can send you a PMC/diagnostic file from 1991 that may help.
    Feb 2010
    46
    machine is made in August 2003 S/N - 3001022101
    Feb 2010
    46
    Hi! i need backup help for MCV720 Dah lih Fanuc series 18-M
    its not that old machine, production date is august 2003, i will try to contact dahlih
    Jun 2008
    1511
    did you get the manual I sent via email?
    Stevo
    Feb 2010
    46
    Yes i got it! Thank you Stevo!
    BTW i managed to fix most parameters and machine works almost normal now, but i cannot travel Y ax to zero return point, any tips?
    Hopefully manual from stevo will help with that
    Jun 2008
    1511
    Any alarms when it stops? I would not think it is referenced if it never made it to the switches.
    Feb 2010
    46
    Quote Originally Posted by stevo1 View Post
    no alarms, sometimes after i move it with handle then it starts to show overtravel but when freshly started it just stops before without slowing down
    Jun 2008
    1511
    That's odd. Does the refernence lights show that it is referenced? It could be something with being so close to the softlimit settings. Is that the alarm you get when you use the handle is "softlimit overtravel"?
    It sounds like your softlimit settings are causing you problems. Although usually if you powered up in the overtravel area it would display the alarm right away. These are parameters 1320 and 1321. Write down what they are then adjust them to 999999 and -999999. If the axis still does not move set them back to normal.
    Stevo
    Feb 2010
    46
    Stevo
    I already tried to play with those 2 parameters but that just allows how far you can travel without alarm, but it stops before that when using referent zero return without over travel alert, i think i got idea now but will have to try it tomorrow
    Thanks for trying
    Feb 2010
    46
    Still looking for possible solution
    anyone got ideas?
    btw if i do G91 G28 X0 (absolute wont be recalculated right) only works right using Zero return.
    Jun 2008
    1511
    Does the machine move in JOG mode? How far?
    No your machine will not recalculate your 0 when using G28. G28 is just a code to take you to your reference position.
    Stevo
    Jan 2010
    HI, I have a Puma 250M lathe with Fanuc 18T and get a 2028 alarm spindle rotation condition is not ready?? Any ideas? Thanks Jim 714 6121480
    Feb 2010
    46
    Stevo
    Yes it moves in jog normally where ever you want unless you bump over travel.
    I know G28 isnt a zero ref return, but just to move to last zero ref set.
    but i still did t manage to fix my problem, its a bit weird... its not that big problem but its a bit annoying that i have to do ref zero return after using handle/jog/rapid manually if i want program to travel to right position, since all other machines work normal and im used to not having to care about that
    any tips welcome...
    btw i still didt try to change one keeprelay setting that might help
    Mar 2007
    Hello Stevo
    Could i also get a copy of that manual it would a huge help my machine still down same make and model Dahlih.
    Dec 2012
    395
    Hi Dez,
    Do you need the Fanuc-manuals?
    At the next link you can find the pdf-manuals for the 18 Model B and C.
    Series 16/18 Model B
    Series 16/18-B Description Manual, GFZ-62442E/02
    Series 16/18-B Hardware, GFZ-62443E/02
    Series 16/18-B Function Connection Manual, GFZ-62443E-1/03
    Series 16/18-TB Operator Manual (Lathe), GFZ-62444E/03
    Series 16/18-B Maintenance Manual, GFZ-62445E/03
    Series 16/18-B Parameter, GFZ-62450E/02
    Series 16/18-B Operator Manual (Machining Center), GFZ-62454E/04
    Series 16/18-PB Description Manual, GFZ-62622EN/02
    Series 16/18-PB Function Connection Manual, GFZ-62623EN/01
    Series 16/18-PB Operator Manual, GFZ-62624EN/02
    Series 16/18-PB Parameter Manual, GFZ-62630EN/02
    and
    Series 16/18 Model C
    Series 16/18-C Description Manual, GFZ-62752EN/01
    Series 16/18-C Hardware Connection Manual, GFZ-62753EN/01
    Series 16/18-C Function Connection Manual, GFZ-62753EN-1/01
    Series 16/18-C Operator Manual (Lathe), GFZ-62754EN/01
    Series 16/18-C Maintenance Manual, GFZ-62755EN/01
    Series 16/18-C Parameter Manual, GFZ-62760EN/01
    Series 16/18-C Operator Manual (Machining Center), GFZ-62764EN/01
    Series 18-C Descriptions Manual, GFZ-62792EN/01
    Series 18-MC Operator’s Manual, GFZ-62804EN/01
    www.prodsa.com.ar - /integradores/Manuales Tecnicos/Servo_FANUC_Motion/CNC/CNC/iDocs for CNC/LEGACY CNCs/
    Click also on [ To Parent Directory ] for more Fanuc stuff.
    Regards,
    Heavy_Metal
    The Netherlands.
  1. Dahlih MCV 1020 Fanuc 10m
    By burbankbrewer in forum Fanuc
    Last Post: 10-30-2017, 11:32 PM
  2. Mode switch for Fanuc 10m on a Dahlih 1020mcv
    By davestewart53 in forum Want To Buy...Need help!
    Last Post: 03-11-2010, 04:19 PM
  3. Fanuc 10M on Dahlih MCV 760.
    By Jakes in forum Fanuc
    Last Post: 01-28-2009, 10:06 PM
  4. manual parameters fanuc 6m
    By Olsson in forum CNC (Mill / Lathe) Control Software (NC)
    Last Post: 04-01-2007, 06:05 PM
  5. Dahlih MCV 1020 Fanuc 10m
    By burbankbrewer in forum Community Club House
    Last Post: 11-15-2006, 05:44 PM
