585,932 active members*
3,711 visitors online*
Results 1 to 18 of 18
    May 2009
    Circular interpolation Fanuc O-M
    Hello I need an example line of code to do a G03.
    I have a Fanuc O-M controller.
    I want to make a 1.25" circle with the with a .75" endmill.
    Can not figure out how to calculate the I & J value or the order to put them in.
    CD
    Feb 2008
    586
    I and J are the distance in X and Y that the center point exists relative to the start point. For example, if you have a point at X.5 Y2. where a circle starts and the circle center is at X.75 Y2., your code would look like:
    G01 X.5 Y2.
    G03 X.5 Y2. I.25 J0
    because the center point is .25 from the start point in X, and no distance from the start point in Y. Hope this is understandable.
    I'm not giving you the answer for two reasons. First, the teach a man to fish thing, and second, I don't know where your circle exists on your coordinate system. Good Luck!
    Apr 2008
    49
    I and J are the distance to center of the Arc in X and Y. Fanuc will read I and J as incremental distance.
    So if you start your arc at 3 O'clock... "I" would be minus "J" would be 0(zero)
    If you start your arc at 11 O'clock.."I" would be positive and "J" would be negative
    Apr 2008
    49
    Quick sample codes for you...
    starting at 9 O'clock
    (G41)G1X-1.0 Y0 F... (feed in to edge of circle)
    G3 X-1.0 Y0 I1.0 J0 ( do full circle, X and Y end points can be left out)
    (G40)G1 X-1.5 (move away)
    Jun 2003
    205
    Circle Milling
    Try this link :
    http://www.kentechinc.com/tip7.html
    Look for the free circle milling code generator on that page ... it will come in handy for ya.
    Real World Machine Shop Software at ... www.KentechInc.com
    Feb 2006
    992
    Let me jump in.
    Is it must I J? If not you can alway just used simple R instead it's just work as good.
    The best way to learn is trial error.
    CNCRIM is right just use R
    I=the distance from the centre point of circle to the start in X with direction
    J=the distance from the centre point of circle to the start in X with direction
    Simple.
    PM me and i'll send you a sheet explaining it all.
    The Fanuc Support Center Team
    www.fanuc-support.com
    Feb 2006
    1792
    But, cannot make a complete circle with R method. The reason is that, for the same start and end points, infinite circles are possible, all with the same radius. In such a case, the circle would need to be made at least in two halves, if R method is desired to be used.
    While both methods can be used, selection should generally be based on how dimensions are specified on the drawing.
    Feb 2006
    992
    Quote Originally Posted by sinha_nsit View Post
    what are you talking about? if you want to make an arc more 180deg all you need is put a munis sign in from of the number like R-x.xxxx.
    Will make complete 1" circle.
    G1X0Y.5
    G3Y.5R-.5
    Feb 2006
    1792
    See the attached figure.
    For the coincident start/end points, infinite circles are possible, all with the same radius. Possibly the machine would make one, which may or may not suit you.
    Attached Files Attached Files
    WRONG (nuts)
    Again i agree with CNCRim
    Feb 2006
    1792
    Have you looked at the figure posted by me?
    It is not that a complete circle cannot be made. But the question is: which circle (see the figure)?
    Feb 2006
    992
    Good point, but we all know that is easiest point of a circle is at 0 90 270 and 360 deg relate to the circle center ....... We just trying to show the fast way to program efficently and it is R, calculated I J is take longer except full circle. Additional note, if your control don't like complete full circle with R like the last post I had and you can help it by program it slicely off by .00005. Can you measure or see the circle is out of round by fifty thousand? I don't think so.
    G1X0Y.5
    G3x.00005Y.5R-.5
    Feb 2006
    1792
    Quote Originally Posted by CNCRim View Post
    G1X0Y.5
    G3x.00005Y.5R-.5
    Good idea.
    However, X0.00005 and X-0.00005 would make different circles.
    The desired circle can be made by manipulating the signs of X and/or Y in G02/G03 block.
    Feb 2006
    992
    /G03 block.
    That's programmer job to know which circle he/she want, you don't think a company pay you for nothing, addition that's what make difference you are experience programmer.
    Apr 2008
    1577
    G1X0Y.5
    G3Y.5R-.5
    Just FYI, not all controllers will evaluate a full arc with the R designation. My Fadal requires I and J when interpolating a full arc. There are very valid reasons for this, which sinha_nsit has illustrated. I couldn't locate a Fanuc manual online but can you verify that the Fanuc control will evaluate a full arc using an R address? If it can, how does the control evaluate where the arc center is??
    Exactly. I would think a company would pay an experienced programmer to be able to calculate an arc center using IJ. (nuts)
    R values are a shortcut. The control looks at the arc radius value, the arc direction, and the arc sweep (degrees) to calculate the I and J for you. Simply put, it can't do that without additional information, such as the direction of the cut before it encounters the arc move. They definitely have their place for expediency (lathe programming comes to mind) but they aren't a substitute for robust programming. Teaching a guy that doesn't grasp the IJ concept to use R is a disaster waiting to happen.
    Apr 2008
    1577
    Quote Originally Posted by fanuc-support.c View Post
    Simple.
    Not even close. The J for X value was probably just a typo but there is a major difference between the vector quantity from the center of a circle to the start, as opposed to the vector quantity from the start to the center. The magnitude (distance) is the same but the direction is not.
    Feb 2006
    1792
    Yes. Center method is the basic method. R method has been made available for our convenience. R method, however, cannot be used in certain cases where it may not work or may give incorrect/inaccurate results. For example, as per 0i manual, it should not be used when the arc is close to 180 degree since "the calculated center coordinates may contain an error. In such cases, specify the center of the arc with I, J and K".
  1. Circular Interpolation
    By Deadwood in forum Mach Software (ArtSoft software)
    Last Post: 01-11-2009, 09:35 PM
  2. circular interpolation
    By sqatch in forum Dolphin CAD/CAM
    Last Post: 02-11-2008, 07:02 AM
  3. Circular or Helical Interpolation?
    By meme in forum MetalWork Discussion
    Last Post: 10-30-2007, 09:05 AM
  4. Circular interpolation problem
    By L. Sakthivel in forum Fanuc
    Last Post: 10-17-2007, 08:26 AM
  5. No circular interpolation in G-Code?
    By M30 in forum Mastercam
    Last Post: 07-25-2007, 03:55 AM
