585,712 active members*
3,780 visitors online*
IndustryArena Forum > MetalWorking Machines > Hyundai Kia > Hyundai Kia SKT 250 Fanuc OI-TC ---RPM Problems
    Apr 2009
    If you program spindle speed of 100, it will run at spindle speed of 188. It seems to run 88 percent faster than programmed. Is there a parameter that needs to be set?
    Feb 2006
    992
    Is this lathe or mill? If lathe it's normal because bigger diameter take more time to travel, so when the tool travel to the center the spindle suppose to rev to infinity. since that had been said nothing wrong when the spindle faster than program number.
    The best way to learn is trial error.
    Feb 2010
    If you run it in G96 than it will be changing RPM with diameter, if you setup G97 you will have constant RPM no matter what diameter you cutting.
  1. FANUC 5T problems
    By Dragoon2 in forum Fanuc
    Last Post: 12-12-2008, 07:24 PM
  2. fanuc oi-tc on a hyundai-kia skt21
    By mekdad in forum Fanuc
    Last Post: 12-11-2007, 01:01 AM
  3. Hyundai 30M Problems
    By atmosports in forum DNC Problems and Solutions
    Last Post: 09-28-2006, 07:05 AM
  4. Fanuc 3TC problems
    By roni21702 in forum Fanuc
    Last Post: 03-15-2006, 06:00 AM
  5. Fanuc Problems
    By scuba in forum MetalWork Discussion
    Last Post: 03-19-2005, 08:19 PM
