585,733 active members*
4,565 visitors online*
Page 1 of 2 12
Results 1 to 20 of 40
    Jun 2009
    267
    80/20 Gantry Beam Prototype
    Well when you're snowed in for a week and nothing else to do it sure gives you plenty of time to design new stuff. This is my latest creation, a whole slew of stolen ideas from here at the Zone!! The main gantry beam is to be of 80/20 size 3060. I couldnt find a Sketchup model of that particular size so I just drew it as a solid beam but it is actually 3060. I ran the deflection caculations and with a width of 60" (more than mine here) and 3060 in size with a load of 50 lbs the total downward deflection was .001 and Y direction was a little more at .005. Both numbers are good to me and Im waiting to talk to the good folks over at 80/20 to see if they can help me take cutting forces into effect but it looks like a single piece of 80/20 is going to work fine for this new design. I did the numbers at 50lbs but I dont think it will be that much, maybe.
    The Z slide is shamlessly taken from the Mechmate design so it should be good to go. The sliding Z plate will of course have to be machined flat and true but thats minimal.
    I was going for a really light, streamlined design without a lot of unnecessary parts. Im getting there but I keep looking at this thinking there could still be an easier way. Thoughts?
    As usual please look it over and see what you think, comments suggestions please!!
    Attached Thumbnails Attached Thumbnails 8020 CNC Build1.jpg   8020 CNC Build2.jpg   8020 CNC Build3.jpg   8020 CNC Build4.jpg
    8020 CNC Build5.jpg   8020 CNC Build6.jpg   8020 CNC Build7.jpg   8020 CNC Build8.jpg
    Oct 2009
    272
    Why Change the Gantry design?
    Nice work. It does look more "streamlined". Why the change from a double rail gantry? I'm assuming the rail plates for the v-rollers are steel. That would certainly decrease the amount of deflection, or did you account for that in your calculations? Have you ordered parts and when do you plan on starting your build?
    Just wanted to say good job.
    Randy,
    I may not be good....
    But I am S L O W!!
    Feb 2010
    202
    If you turn off the electronics, engines will not hold, the axis Z of the fall
    Jun 2009
    267
    Well honestly Randy I havent decided yet which way to go. I like the idea of the double beam gantry but I was looking around at some other designs and just wanted to try something different.
    Bartuss, Im not sure how the Z slide stays in place but I know this is how the Mechmate routers are built and it works for them so I have to do some research on that. What holds the Z in place on any other routers when the power is off?
    Feb 2010
    202
    Self-locking bolts or pneumatic actuator
    Jun 2009
    267
    Ok I just re-read the thread over at the Mechmate forums and it seems the Mechmate guys use a gas spring, kind of like the things that hold your hood open on a car. You just need to match the weight of your Z slide to the right gas spring. This holds the Z car in place when power is turned off. Should be an easy enough mod for my design I would think. More pics to some soon!!
    Oct 2009
    272
    Gas strut!
    So, will you be ordering the gas spring from Lamborgini, or is this a budget build and go for one from a Yugo? lol.
    But I am S L O W!!
    Jun 2009
    267
    Funny!! Actually Mcmaster Carr has a good one that looks about right.
    http://www.mcmaster.com/#9432k64/=5sbzb1
    Should be fine in the 20 lb range.
    Nov 2009
    39
    nice design
    I like the design, it looks clean and compact. For my current build, I'm gonna stick with the double gantry design like the mechmate just because it is actually different than what everyone is doing on this forum. The single gantry is much simpler though.
    The mechmate uses the gas spring as a counter balance against the forces of gravity. The motor they used also has built in gearing of 7.2:1. I would think this would also help to hold the z-axis in place with such a high gear ratio.
    The rack and pinion design allows for much faster speed but I don't know if it's worth the extra issues that you run into like Baruss1 mentioned. Since your travel is so limited, a screw drive seems to be much simpler for the Z-axis. If you incorporate some kind of worm drive into your gearing, that would solve the problem of the Z-axis falling when the motor is powered off.
    Keep the ideas coming!!! I'm building mine right now but am changing the design everyday as I go.
    Diyaholic,
    funny you mentioned lamborghini... me and the other builders at kitcentral.com are using the gas springs from McMaster Carr for our Lamborghini kit car!!
    Steven (Van)
    Aug 2004
    54
    how do you propose to grind the V-edges on your rails ?
    sincerely,
    rjs
    Jun 2009
    267
    Steve do you have a build log going on? Id love to see your design for a double beam gantry!! Also what did you mean by my limited Z travel? Right now I will have about 7 inches under the gantry of Z travel, is that what you meant?
    RJS, I havent decided if I will grind the rails myself or just purchase the V track for the V bearing rollers. If I grind them here I have a plan for a jig to use with my 12" disc sander that may or may not work, still working on that. If not there is always the Mechmate "skate" that seems to do a good job of grinding them properly.
    Nov 2009
    39
    build log
    I posted the link to my build log in your 'Aluminum Mechmate' thread but here it is again...
    http://www.cnczone.com/forums/showthread.php?t=99181
    What I meant about the Z-axis is that there is no advantage to using a R&P design on the Z-axis since the travel is short enough that you don't need the speed of the R&P system. That is the advice I got from Ahren, the seller of this system. He is a member of this forum and a very informative guy.
    With that said, I would not frown on using R&P on the Z-axis, if you can make it compact. Your design looks very compact especially with the Y and Z motors mounted together. Since I am using of the shelf components, the R&P drive system I purchased is very large. In the future, I will opt to buy a stepper motor with a built-in reduction gear like the ones the Mechmate folks use.
    Jun 2009
    267
    The finished design
    Well it took me most of the day but I got the design completed. Right now Im showing it done all in 80/20 size 2020 but cost may come in to factor there. If so I will more than likely go with 2x2 tube steel since I can source that at a good price locally. I do like the idea of the 8020 better though for ease of construction and the ability easily modify if need be. Also the legs for the table will be taller but when I drew them in it made the whole model so tall that no details could be seen so I drew them in short for now.
    The only main things left off is the motors and R and P drive for the X axis. I will more than likely use the cncrouterparts.com R and P system since it works so well with their linear carriages Im already using on the X.
    All in all Im pretty happy with everything and cant wait to get started which I hope to do as soon as I can find my shop again. Right now its under about 6 ft of snow from the drifts!!
    As usual comments and suggestions are MORE than welcome.
    Thanks for looking!!
    Jim
    Attached Thumbnails Attached Thumbnails 8020 CNC Build12.jpg   8020 CNC Build13.jpg   8020 CNC Build14.jpg   8020 CNC Build15.jpg
    Dec 2006
    406
    I think the design looks good but... How is the gantry kept from lifting off the rails? Looks to me like you need to turn the long rails 90 degrees and put them on top of the8020. Also turn the bearings to match. This will lock the gantry from coming off. Good luck.
    Judleroy
    Oct 2009
    272
    Cool The Envelope please!!!
    I see you have made the decision to go with the single rail gantry. What swayed you? Also, what is your final (projected) work envelope going to be?
    BTW, nice job.:cheers:
    Randy,
    But I am S L O W!!
    Jun 2009
    267
    Quote Originally Posted by judleroy View Post
    Judleroy
    CRAP!! Those were supposed to be vertical not laying flat!! I cant believe I did that. Oh well back to the drawing board!! Thanks for picking up on that.......:withstupi
    Jun 2009
    267
    Quote Originally Posted by DIYaholic View Post
    Randy,
    Well the main thing was cost and ease of build. This whole thing can more or less go together like a big erector set with very little custom machining or special work needed to be done. I like that part. Also the cost. Im attaching my spreadsheet to this for a breakdown of the major costs. Now I know there will be some items I forgot but it covers all the major expenses with the exception of a PC and software. The prices are directly from ebay and speedy metals. Actually I can probably bring this in even less buy getting alot of the non-8020 stuff locally here. Some other items are from Mcmaster Carr and then of course the ever faithful homecenter items.
    Attached Files Attached Files
    Aug 2005
    231
    Talking
    Too funny! I'm building my new CNC (32" x 18", way smaller than yours!) to build bigger stuff for the guys on Kitcentral... I use my modified Taig machine to build the replica HVAC units. I'm also using 3060 for the gantry... Cool stuff!!
    Jun 2009
    267
    FIXED
    Ok I got it right now, the linear carriages are oriented now in such a way as to constrain the movement of the gantry to the X direction only and with no lifting either. Thanks again for pointing that out to me!!
    PS This will be approx a 4x6 cutting area router....at least thats the plan!!
    Attached Thumbnails Attached Thumbnails 8020 CNC Build16.jpg   8020 CNC Build17.jpg   8020 CNC Build18.jpg
    Jun 2009
    267
    Rack and Pinion Setup
    For the X axis I will more than likely go with cncrouterparts.com rack and pinion set. Its ready made for the 80/20 as well as the linear carriages Im using from the same company.
    ATTN: Ahren,
    If you get a chance to look over my design and let me know what you think that would be great. I think everything should be good to go but I just want to make sure.
    Thanks!!
    Jim
    Attached Thumbnails Attached Thumbnails 8020 CNC Build19.jpg   8020 CNC Build20.jpg   8020 CNC Build21.jpg
Page 1 of 2 12
  1. Fixed gantry vs moving gantry
    By scott0999 in forum DIY CNC Router Table Machines
    Last Post: 01-31-2014, 06:14 AM
  2. Router Gantry Beam strenght and vibration?
    By Knut in forum DIY CNC Router Table Machines
    Last Post: 12-27-2010, 06:29 PM
  3. Gantry: planning to design moving open gantry
    By rdcd in forum Mechanical Calculations/Engineering Design
    Last Post: 11-14-2009, 10:52 PM
  4. How align IR beam (co2) with visible beam (red dot laser) ?
    By etienne delcuve in forum Laser Engraving / Cutting Machine General Topics
    Last Post: 02-04-2009, 12:41 PM
  5. Short beam/Long beam? - Basic design
    By Pat2000 in forum Mechanical Calculations/Engineering Design
    Last Post: 11-10-2005, 05:49 AM
