585,712 active members*
4,082 visitors online*
    Jul 2009
    7
    FANUC 16M Problems...
    Getting the following:
    -414 SERVO ALARM Y AXIS DETECT ERROR
    -Diagnostic display reads "REGENERATIVE DISCHARGE CURRENT ALARM IS BEING GENERATED IN SERVO AMP-CHECK LED"
    -Servo amp has 3 display options, 5=READY, - (dash)=not ready, 0=alarm. It displays the dash (not ready)
    It has happened to me twice while machine is running, but most times its at start up, it seems that after it warms up a bit inside the panel it will display ready (5) and it will start up, I am unable to move either axis until it diplays ready. It took 2 hours to get it going this morning. Once fault clears runs fine but problem again in the morning. Thx in advance for your help
    Work your way through this and report back
    GL.
    *~~Darwinian Man, though well-behaved, At best is only a monkey shaved!~~*
    *__________If you feel inclined to pay for the support you receive__________*
    *_______Please give to charity https://www.oxfam.org.au/get-involved/_______*
  1. Fanuc 11 crt problems
    By bofr in forum Fanuc
    Last Post: 06-10-2021, 09:29 PM
  2. Fanuc DNC problems
    By bigfoot in forum Fanuc
    Last Post: 01-25-2010, 05:34 PM
  3. FANUC 5T problems
    By Dragoon2 in forum Fanuc
    Last Post: 12-12-2008, 07:24 PM
  4. Fanuc Problems
    By timmyv in forum CNC Machining Centers
    Last Post: 09-23-2008, 10:05 PM
  5. Fanuc Problems
    By scuba in forum MetalWork Discussion
    Last Post: 03-19-2005, 08:19 PM
