585,898 active members*
4,571 visitors online*
    Feb 2010
    Cutting XPS foam with cheap laser?
    First of all, I have no experience with lasers.
    Is there a cheap laser (~150EUR) that can cut 10cm thick XPS?
    AFAIK, there are two types of lasers: laser-diodes and real-lasers.
    I guess real-lasers would cut XPS with no problem but are expensive.
    Are laser-diodes strong enough to cut XPS?
    I understand that laser-diodes are better suited for engraving,
    because of focus problems, right? If I would somehow change the
    focus dynamically, would it then cut 10cm of XPS? At what speed?
    Thank you.
    Dec 2008
    1258
    Short answer: No.
    It would be a challenge for any laser to cut 10cm (4 inches) of XPS foam.
    A CO2 laser and correct optics would work, but you won't get a parallel cut.
    Hot wire is the best method for that thickness of foam, and much cheaper too.
    Zax.
  1. Laser cutting craft foam, have you done it?
    By rpage in forum Laser Engraving / Cutting Machine General Topics
    Last Post: 03-20-2015, 11:31 AM
  2. Laser cutting eva foam
    By James80 in forum Laser Engraving / Cutting Machine General Topics
    Last Post: 03-07-2015, 08:04 AM
  3. Laser Cutting Foam
    Last Post: 03-17-2009, 02:21 PM
  4. Build a cheap, SIMPLE, CnC foam cutter.
    By moreil in forum CNC Wire Foam Cutter Machines
    Last Post: 01-05-2009, 03:09 AM
  5. Cheap foam for testing a CNC program
    By replicapro in forum MetalWork Discussion
    Last Post: 06-09-2006, 07:12 PM
