Originally Posted by
beamsjr
I have just finished cutting out and assembling the Joe's 2006 router. The Y axis seems to jerk a bit when moving. When I push back and forth I can not feel any looseness. I am just curious what might cause this? I was thinking maybe a bad bearing... Also should I have a bearing on the lead screw at the back of the gantry?
Also what kind of speed should I be getting? Anything over about 30-40 IPM and the motors stall. I am using the hobbycnc pro board and the 305 motors. Does this sound about right?
Thanks, Joe
you should easily be getting 80-100ipm, not sure what you mean by a bearing at the back of the gantry can you take a picture of the area. Also use white lithium grease on the leadscrews to ensure smooth and easy turning of the leadscrew.
Joe
www.joescnc.com
joecnc2006 at yahoo
