Hi All,
I have three g203v gecko drives and three stepper motors from Kelling Tech (KL34H260-42-8A). I also have the CNC4PC breakout board C11 Multi-function board. I am thinking of using two motors to drive the x-axis (2 roton ball screws drive the x-axis) and was wondering if the BOB would work for this.
I know I need another gecko drive and motor, but was wondering how I can drive the two x-axis motors in sync or if this is problem. I also have the KL-7212 (Unregulated Power Supply 864W, 72VDC/12A, Single Rectifier Module,120VAC or 230VAC) and was hoping that this is enough power to drive four motors.
Also should I power the BOB and other low voltage electronics with a separate power supply (5v-12v)?
The router is an all metal/aluminum and I will use a Chinese Spindle. I want to be able to cut soft metals (aluminum, brass, copper, etc.) and wood of course.
What other electronics, besides a PC will I need? E-Stop, home and limit switches, etc. If someone has a list of the needed electronics, plus nice or neat stuff to add to the system for smoother or better operation, I am highly interested in any help. Also I have Mach 3, but what other software do I need? I don’t understand the difference or what I need to consider.
Of course my budget is limited, so I need to make some smart informed choices, thanks for your help.
Paul
