Originally Posted by
kae
I am not currently using the disable pin on my Gecko 203v but I have a question concerning what happens when the disable pin is used.
I have discovered that the stepper motor is held as soon as my DC supply is powered up thereby rendering manual movement of the axis impossible. My question is if the disable pin is pulled high, does it allow the motor to become freewheeling?
Thanks in advance for your help.
I believe you are correct in that it turns off all of the output from the drive allowing it to freewheel. If you go to the Gecko website under support and download the manual it goes into further detail.
Mike
Warning: DIY CNC may cause extreme hair loss due to you pulling your hair out.
