so i have been running the mill pretty hard and i am noticing that the head moves a lot while cutting. i was noticing steps on the surface of parts like the head is out of tram, but i just trammed it in. the steps are opposite each other on each side of the part as it is cutting ccw(digging in on the left when moving one way and digging in on the right when moving the other way), so i figured the head must be moving. i started the program and watched it and can see it move side to side relative to the collumn as it switches directions, and it is missing the insides of the part by .030" or so. this is mostly side to side, not so much front to back, but i noticed the head tram is off front to back, but the only way i can think to correct that is to shim with shim stock or something of that nature. anyway, it appears to move within the z linear bearings. i am running a 1/2" 3 flute carbide high helix em at .25" doc 45% stepover 4000rpm, 30ipm in aluminum, so pretty aggressive i think for this mill, just curious if anyone else is seeing this problem. i am cutting an oil pan for a kawasaki ninja zx10r about 10.5"x10.5" so the spindle runs for 35-40 minutes solid just for this first roughing, so i am letting it sit and cool before the next roughing opperation, and then finish passes. anyone experienced problems running this hard this long??
Jesse
