585,931 active members*
3,576 visitors online*
Results 1 to 8 of 8
    Feb 2010
    meldas 500 series
    Hi there!! wonder if someone can help me??? I have a meldas 500series and would like to drip feed from my pc, but it doesnt work??!!
    Jul 2007
    284
    Aug 2009
    71
    Need Help! meldas 500 series
    Try attached procedure, give feedback if any corrections needed.
    Regards,
    Girish
    Attached Files Attached Files
    Aug 2009
    71
    Sorry,
    I think the default port no. for M500 series is 1. The attached procedure was prepared on basis of M60 series, but never tested.
    So in the Step 2) set the par 6 Hostlink Port – 1, Device – 4. and not 2.
    Regards,
    Girish
    Jul 2007
    284
    girishdk,
    That procedure is for Computer Link which requires additional hardware and option install on the 500 control.
    Aug 2009
    71
    Hi onthebumper,
    You are right, this option is required.
    As per feedback from our customers, for Die-Mould application with dripfeed, i think it is minimum required.
    When using Dripfeed without HOSTLINK, i am afraid only 7-8 blocks will be transferred from PC to CNC buffer at a time.
    With HOSTLINK i think 248-4096 blocks will be transferred at a time to NC buffer & hence the speed is more, finish better.
    Above is our thinking from the feedback we received from our Die-Mould customers.
    Any feedback of your experience is most welcome.
    Thanks a lot & Best regards,
    Girish
    Jul 2007
    284
    Girish
    Yes you are correct. You can drip feed without Computer Link option but the finish on the part will not be so good if you are doing small movements like Die/Mold is doing.
    Computer Link option is much better for Die/Mold because of the buffer.
    I just wanted to clarify that the option would need to be purchased to follow your procedure.
    Ethernet option for 500 control is also a very nice option for Die/Mold with much higher speeds and better reliability, in my opinion.
    Feb 2010
    Talking meldas 500 series
    thanks for all your feed back guys,will try all of the above and see if it works.
  1. How to initial parameter error meldas 300 series
    By gunawan_tehnik in forum Mazak, Mitsubishi, Mazatrol
    Last Post: 01-06-2023, 08:07 AM
  2. Meldas 500 Series
    By ScoobyDoo in forum OKK
    Last Post: 08-23-2021, 04:52 PM
  3. problems while booting MELDAS 300 series CNC LEADWELL TDC 450.
    By perfect in forum Mazak, Mitsubishi, Mazatrol
    Last Post: 02-08-2016, 04:16 PM
  4. MELDAS 300 series
    By DANMI38 in forum Mazak, Mitsubishi, Mazatrol
    Last Post: 03-09-2009, 04:59 PM
  5. meldas 50 Series
    By nastek in forum Mazak, Mitsubishi, Mazatrol
    Last Post: 01-01-2007, 04:32 AM
