585,930 active members*
3,918 visitors online*
Page 5 of 5 345
Results 81 to 88 of 88
  1. #81
    Jul 2007
    675
    Re: The Dyna Myte 3000 Project
    Quote Originally Posted by Big Chips View Post
    like your videos on youtube...wish you would put up a vid showing how to touch off the tools... thanks for the reply
    I will be using the 3000 on my next kickstarter. Will do
  2. #82
    Mar 2007
    304
    Fastest1 - Could you post your .DXF files of the motor mounts for the rest of us ?
    www.CNC-Joe.com
    CNC Is Not Just My Passion.. It's My Addiction !!!!
  3. #83
    Nov 2009
    4415
    Hope this works for you. Btw, I use BobCad. That file looks terrible in my autoviewer or whatever opens the dxf.
    A lazy man does it twice.
  4. #84
    Mar 2007
    304
    Thank You! I just saw that you had placed that out there. Sorry for that!
    www.CNC-Joe.com
  5. #85
    Sep 2012
    323
    Where did you get the pulley you used for the X axis to replace the plastic gear?
    Having a hell of a time finding anything that looks like that besides "gear stock"
    Andrew
  6. #86
    Nov 2009
    4415
    I did make it from gear stock. They come in all sizes and tooth profiles. SDPI.
    I just got a set of direct drive mounts for Dyna's. It was from a member here that had an impressive build many years ago. Here is what I got. A link to his build.http://www.grifftek.com/images/dyna2400remec/
  7. #87
    Sep 2012
    323
    Quote Originally Posted by Fastest1 View Post
    That's not for the DM 3000 is it? If so would you mind sharing the cost?
    Sent from my Nexus 6 using Tapatalk
  8. #88
    Nov 2009
    4415
    Most likely they will work on all this class of dyna's, 2200, 2400, 2800 & the 3000. He was cleaning out his storage and sold me all of it. 5 mounts, 3 sets of couplers a few steppers. The only limitation I can see is maybe due to the thickness of the mount it will lose some travel due to the enclosure of the lathe. It would be a minimal loss on the lathe and most likely not taking any cuts at max diameter. Unfortunately I think my enclosure I built for the mill years ago might have the same issue. I have no intention of losing any travel on the mill.
Page 5 of 5 345
  1. dyna myte 3000 lathe
    By davidponte in forum Dyna Mechtronics
    Last Post: 01-27-2013, 04:50 AM
  2. DYNA MYTE 3000
    By SUE143 in forum Dyna Mechtronics
    Last Post: 04-09-2012, 06:00 PM
  3. dyna myte 3000 lathe
    Last Post: 04-15-2011, 05:02 PM
  4. DYNA MECHTRONICS DYNA MYTE 3000 AND 2800 WANTED!!!
    By britcollector in forum Want To Buy...Need help!
    Last Post: 02-23-2010, 04:20 AM
  5. Dyna Myte 3000 found a new home!
    By Fastest1 in forum Dyna Mechtronics
    Last Post: 02-20-2010, 11:42 PM
