Ok got my mill the other day and must say it's alot bigger than expected. Everything was packed very nice, some stuff got scratched a little bit and a few bad gashes, but nothing a little paint won't solve.
Only problem was that the bottom of the pallet is spaced weird and my pallet jack doesn't fit thru the center. I've got the jack set at an offset (forks to the heavier side) and noticed I've got a big problem. My pallet jack doesn't go high enough to get the shop crane forks underneath the wooden pallet. So I need a few suggestions on what to do ?
** I was thinking about add a few pieces of 2 - 3" aluminum flat stock on top of the pallet jack forks to add height.
One other thing, when you guys installed the iron feet to the bottom of the stand, afterwards did you completely extend the iron feet to make room for the shop crane or should I keep them right on the cast iron spacer ?
