YOu know like G54, G55, ECT?
Thanks.
Thanks.
It depends on the age of the machine.
Older machines with the CRT monitor recognise G54 to G59 and G110 to 129, newer machines have many more available b ut I don't know the actual number.
In practise, however, if you use a G10 command you can relocate any work zero on the fly in a program so you can have an unlimited. Also you can set a single main work zero and then use G52 to create as many secondary work zeros as you like.
Geof,
can you post that link to the g10 command that has examples ( I know you posted one a while back just cant find it and I am lazy
I have 3 vices and didnt want to write one program to fit all so I used
g55 g56 g57 etc etc for each part ( 5 parts at a time)
it was an easy edit ( program I had before was for one at a time 10 parts total, now I have 200 parts total so I did 5 at a time) for the program kinda it had 7 tools but I am thinking the g10 would have worked better/easier to program. or at least a sub but I suck at writing subs with out a working example.
Delw
