586,000 active members*
4,925 visitors online*
IndustryArena Forum > MetalWorking Machines > Daewoo/Doosan > Puma 230M left hand tapping
    Feb 2010
    Question Puma 230M left hand tapping
    I have a Puma 230M and I want to run a G84 tap cycle. It is a left-hand thread though. If I command with M34(I want to use my live tooling). There is no reversal during retract. Is there a parameter I need to change? Or is it just not doable this way on this machine?
    Eric
    2932
    I believe you need an M72 before the M29 block, and an M73 after the G80 block (see attached).
    Attached Files Attached Files
    Feb 2010
    Thanks dcoupar
    Worked out just fine.
    Eric
    2932
    Glad I could help.
  1. Left hand tapping
    By Get lucky in forum G-Code Programing
    Last Post: 05-28-2012, 04:10 PM
  2. left hand 3-48?
    By skmetal7 in forum Mechanical Calculations/Engineering Design
    Last Post: 05-05-2009, 07:49 AM
  3. Rigid tapping Left hand
    By DocHod in forum Fanuc
    Last Post: 06-20-2008, 05:54 AM
  4. can the tailstock be programmed on Daewoo puma 230m
    By Bigbill in forum Daewoo/Doosan
    Last Post: 05-25-2007, 01:38 PM
  5. coverting from Right-hand to left-hand coordinate system
    By eltonr in forum Uncategorised CAM Discussion
    Last Post: 10-15-2004, 02:40 AM
