585,970 active members*
4,426 visitors online*
    Jun 2008
    562
    Mach3 Rev 3.04 VS Rev 1.84
    Before they went out of bussiness I asked Dynacnc if the machine would run with the newer versions of Mach 3. All I got was NO... no explanation. Is anyone using Rev 3 of Mach with thier Dyna machine versus the ancient Rev 1.84? If so, what was req'd to get it going?
    Mike
    Jul 2005
    2415
    Depends on the controller version. I can't think of any reason it would not work with something like 3.42.020. I know for a fact that the DYNA1000 series interface (our older MP1000 controller) WILL work with new versions of MACH. I think the reason you got that answer may be because they never took the time to try it. It is possible their later 4000 (and 6000) series controllers would not work with later versions but it would only be if there were some really strange links.
    If you have one of the 1000 series contact me and I can help you upgrade the software. The same MACH profile should work.
    TOM Caudle
    www.CandCNC.com
    Jun 2008
    562
    Quote Originally Posted by Torchhead View Post
    TOM Caudle
    www.CandCNC.com
    I have a 6000 series controller, I may just give it a try and see what happens, hopefully it won't cause any damage.
  1. 4to eje con mach3
    By dansa0561 in forum Spanish
    Last Post: 07-31-2008, 04:44 PM
  2. BOB and Mach3
    By tpmx57 in forum Machines running Mach Software
    Last Post: 04-27-2008, 11:50 PM
  3. MACH3 ONE TO ONE.....
    By MACH DESIGN in forum Mach Mill
    Last Post: 04-27-2008, 02:05 PM
  4. Mach3
    By routerrick in forum Machines running Mach Software
    Last Post: 01-04-2008, 09:51 PM
  5. Mach3 and USB
    By mikep608 in forum Mach Mill
    Last Post: 08-09-2006, 06:56 AM
