584,866 active members*
4,937 visitors online*
IndustryArena Forum > CAM Software > Mastercam > Contouring a face profile using lathe
Results 1 to 8 of 8
    21
    Using X2 with an older lathe with only X, Z, and Spindle.
    I need to face contour a profile but the only references I can find are dealing with a "C" axis which always gets me into a mill operation.
    Could someone please give me some guidance for contouring the face of the attached part?
    I plan on using 3 triangle shape tools. Right, Left, and straight.
    Many thanks,
    CEM
    Attached Files Attached Files
    Feb 2006
    992
    can't open the file, post pix.
    The best way to learn is trial error.
    21
    See attached.
    Feb 2006
    992
    Toolpath lathe face rought -> and pick the custom groove tool. The round single point grooving tool working out pretty good.
    21
    If I go to toolpaths, I can select rough or face but not face, rough.
    If I do toolpaths, rough and then chain the face contour and select a round nose grooving tool. I keep getting a message of chuck collision. I only chained the face contour and omitted the od segment.
    The toolpath representation shows a heavy incursion into the face if I tell it to go ahead and create the toolpath after the collision message.
    Jul 2003
    263
    why don't you use the face grooving tool path
    If you can ENVISION it I can make it
    Sep 2005
    26
    Cowpoke have you gotten this figured out or would you still like help. Check your plunge parameters if I understand you correctly this should help out.
    21
    Thanks for the help
    Finally finished the face grooving part. My not fully understanding how the plunge parameters function was the primary problem. I did however have to eliminate the 3 small round bottom grooves in each of the larger grooves and then do them with a separate operation. For some reason the roughing pass with a wide groove tool was trying to partially follow the small grooves and making an extra deep groove within the wider groove. Hope that makes sense.
    Anyway I did get it finished with a work around.
    Would still be interested if someone could explain why I had to eliminate the small round bottom grooves in the contour to get it completed.
    Thanks much for the help all,
    Claude
  1. Lathe gurus--face grooving woes
    By trey88 in forum MetalWork Discussion
    Last Post: 06-23-2009, 03:10 AM
  2. PROFILE MILLING ON MATRIX LATHE
    By cncmessiah in forum Mazak, Mitsubishi, Mazatrol
    Last Post: 03-21-2009, 04:22 PM
  3. Lathe OD Profile Help
    By elmi in forum BobCad-Cam
    Last Post: 01-20-2008, 03:16 AM
  4. Tools for threading and face-grooving 6061-Al on lathe
    By SRT Mike in forum Uncategorised MetalWorking Machines
    Last Post: 08-15-2007, 06:59 PM
  5. angular contact bearings face to face??
    By powerfade in forum DIY CNC Router Table Machines
    Last Post: 06-19-2005, 05:01 AM
