Is anyone using Feature CAM for Okuma multus programming? If so what are you using for milling cutter copm settings in FC? Part line? And then entering the radius of the cutter in the control?
That seems to work well for us, except when using chamfer mills, due to the different depth the chamfer mills are used at. Which obviously changes the cutting diameter.
Thanks!
