All -
I told Randy I would post pictures...
My recent BSOD episodes nearly drove me crazy as I tried to complete these, but even without the problems I could never sell these for their actual value. I knew I was doing them for free when I started, but the time I spent on them was surprising. Since it was purely a labor of love, cost was no object, right? The frustrating thing is that I'm sure they'll get pocketed quickly and never seen again. Hopefully, I'm wrong.
They are Geocoins, which are tokens used for Geocaching. The idea is that each coin has a specific mission that participants should help fulfill. Our local Boy Scout Council is encouraging scouts to create and search for caches as a part of the 100th anniversary of scouting in America.
Each coin is cut from 1.5" bronze propeller shaft and faced to 0.150" thick. I reeded the shaft first on the lathe by mounting the tool sideways and feeding it toward the head stock (with the motor off), then indexing 6 degrees and doing it again (and again, and again). The rims on the top and bottom of each coin are 0.020" deep, and the lettering is 0.010" wide by 0.010" deep.
The front (obverse) sides are roughed with a .125" and then 0.025" endmills, and finished with a 0.010" mill (all using a router-HSS). Finally, the inside corners on the BSA logo are squared up with a 30 degree engraving point starting a few thousandths deep (using Rest milling in SprutCAM).
The back (reverse) sides are pocketed with a .125" mill and then lettered with the 0.010" mill. Finally, I inked the lettering before I sprayed them with clear lacquer. All told, it's about three hours of machine time per side per coin plus nearly two hours of cleanup, inking, and spraying each.
Regards,
- Just Gary
