552,658 active members*
1,728 visitors online*
IndustryArena Forum > MetalWorking Machines > Benchtop Machines > Mini Lathe > Sieg C6 front saddle gib screws keep loosening
Results 1 to 5 of 5
    Mar 2014
    1092
    They keep loosening because if I overtighten the screws then the carriage gets too tight. If I tighten just enough then screws gets loose in time and by vibration because the screws never gets locked.
    What would you suggest about this?
    Thanks,
    Suat
    Sent from my MI 5s Plus using Tapatalk
    Feb 2008
    487
    Re: Sieg C6 front saddle gib screws keep loosening
    I assume your gib adjusting screws have lock-nuts - if not, then fit some! No reason for vibration to affect them then!
    Mar 2014
    1092
    I mean these bolts. And two on the other side.
    Feb 2008
    487
    Those aren't actually the gib screws - they are screws used to hold the pieces that holds the piece that hold the gib piece in position. All a bit overly complicated!
    The gib screws are adjusted from below as they push the gib upward to the underside of the bedway - the exploded parts diagram in the manuals give a better idea.
    As they are just retaining screws, a dose of Loctite should stop them backing out - as an fyi, mine have never backed out in 10 years!
    Mar 2014
    1092
    Thanks @kawazuki
  1. Vibration loosening spindle grub screws
    By Rkjt in forum Spindles / VFD
    Last Post: 05-20-2019, 12:50 PM
  2. G0704 Saddle Gib issue
    By onuxis in forum Benchtop Machines
    Last Post: 08-05-2017, 03:20 AM
  3. G0704 Saddle Gib Adjustment Problem
    By CrossSlide in forum Benchtop Machines
    Last Post: 08-18-2015, 11:01 PM
  4. Sieg X2 Gib Problem
    By abr5 in forum Benchtop Machines
    Last Post: 01-28-2009, 04:30 AM
  5. X2 table/saddle/gib alignment
    By sansbury in forum Benchtop Machines
    Last Post: 12-06-2008, 10:27 AM
