591,381 active members*
7,194 visitors online*
IndustryArena Forum > Machine Controllers Software and Solutions > Fanuc > Siemens real-time display wireless CNC electronic handwheel
Results 1 to 1 of 1
    Aug 2024
    8
    Support system
    Supports Siemens S7 protocol, supports various Siemens PLCs such as S7-200/300/1200, and
    Supports Siemens virtual PLC, and is currently compatible with Siemens 808d/828d/840dsl, etc.
    Product features
    1. Adopts 433MHZ wireless communication frequency band, wireless operation distance is 40 meters;
    2. Adopts automatic frequency hopping function, and uses 32 sets of wireless handwheels at the same time without affecting each other;
    3. Supports emergency stop button and 6 button switch outputs, and can also be read and written through network cable PLC;
    4. Supports 6-speed axis selection, 3-speed magnification selection, and can also be read and written through network cable PLC;
    5. Supports reading through network cable PLC, real-time display of Siemens system workpiece/mechanical coordinates, feed
    speed and connection status display;
    6. Supports 5V differential pulse signal, 24V pulse signal and other pulse signal types;
    7. Low power consumption design, 2 AA batteries can be used for more than 1 month.
    Working principle introduction
    1. The electronic handwheel is connected to the PLC through an Ethernet receiver
    1.1. The handwheel transmits the key data wirelessly to the receiver, and the receiver writes the key to the PLC system DB area through the network cable; the receiver reads the data to be displayed from the specified DB area, and then returns the data to the handwheel display screen. The user can customize the read and write DB area base address on the handwheel, so that the handwheel can read and write the PLC DB area data.
    1.2. The receiver supports Siemens S7 protocol. Applicable to PLCS7-200, PLC
    S7-300 and PLCS7-1200.
    1.3. On the PC, first configure the receiver to the server SERVER mode through the network configuration tool, then select the PC connection mode on the WGP-ETS test software, perform the handwheel function test, and confirm that the handwheel function is intact; 1.4. After testing and confirming that the handwheel function is intact on the PC, set the PLC read and write address again through the WGP-ETS test software, select the PLC connection mode, and write the configuration to the receiver; then in the network configuration tool, configure the receiver to the client CLIENT mode, and finally connect and communicate with the PLC that supports the standard S7 protocol through the network cable.
    https://youtube.com/shorts/ZUB9v3nXhDM
    Attached Thumbnails Attached Thumbnails ???XWGP-ETS??(??).jpg   ??2.jpg   ??3.jpg   ???4.jpg
  1. Wireless Handwheel question
    By maki in forum PlanetCNC
    Last Post: 02-13-2020, 09:12 AM
  2. Replies: 0
    Last Post: 06-16-2016, 06:05 AM
  3. XHC Wireless Handwheel
    By jpstudio in forum Controller & Computer Solutions
    Last Post: 05-01-2015, 10:19 PM
  4. Replies: 5
    Last Post: 09-04-2014, 12:49 PM
