547,521 active members*
2,001 visitors online*
IndustryArena Forum > MetalWorking Machines > Milltronics > Silly question, screen is reporting mm need inches
Results 1 to 7 of 7
    Jul 2006
    130
    Might be missing something in the documentation but my control is currently reporting everything in mm and I'd like to switch over. This is consistent between reboots not something I did. must be a parameter.
    Dec 2017
    72
    Re: Silly question, screen is reporting mm need inches
    There is a parameter. If I recall, its under param>level>proto3>3>power or similar. Something like startup units. Mine was inches, but I work in mm.
    Be very careful in there, lots of setting that can make a mess of your machine. Dont change a setting unless you know what it's for.
    Sent from my SM-G955U using Tapatalk
    Mar 2010
    16
    Save your parameters before you make changes!
    Jul 2006
    130
    Quote Originally Posted by sjctool View Post
    Dumped them to disk, thanks. I'll worry about tweaking that one thing later, easy enough to reset by hand for now.
    Need to replace the air filter thats on it, its leaking, but working well enough to test out tool changes.
    Jul 2010
    535
    Hi Yugami, Yes the power parameter Boot to English or Metric. set to English. you can also do a G20 in MDI but that is not permanent like the power parameter.
    sportybob
    Jul 2010
    535
    Here is the ONLY silly question I can get. It is 5 OClock on a Friday and the work is done. Hey Bob, would you like a barley pop. Now that's SILLY. ;-)
    sportybob
    Apr 2021
    5
    Angry Re: Silly question, screen is reporting mm need inches
    I know this is an old thread, but I advise you to be careful with your car. If you don't know, it's better to have someone else set it up for you. I once tried to convert millimeters to inches myself, pressed obscure buttons, and thought it worked. Continued working, eventually in the evening the boss measured with a https://ruler.onl and it turned out that I did not match the dimensions. I was so mad - you can't imagine how I got angry - the whole day had been wasted.
  1. Silly Question
    By wildrat in forum Machines running Mach Software
    Last Post: 09-10-2014, 07:11 AM
  2. Silly Question
    By Son of Aslan in forum Commercial CNC Wood Routers
    Last Post: 06-21-2012, 09:48 PM
  3. Silly Question
    By Smitty911 in forum Alibre Design
    Last Post: 12-21-2010, 06:30 PM
  4. Silly Question
    By Smitty911 in forum CamBam
    Last Post: 02-11-2008, 10:30 AM
