I am running v25. When trying to do a simulation I get the error message ( Simulation object loading error. No operation is defined ). What thing or things am I doing that would make the software throw this error code?
Thanks,
Ernie
Thanks,
Ernie
That error indicates that you've loaded the simulation without generating any valid cutting paths, were cutting paths visible before you loaded the simulation?
If you upload a problem file I can take a look,
Regards,
Nick
Nick,
This setup is for milling 12 pieces in one fixture. I had a brain fart and drew the 12 pieces then selected countour on each one. I did'nt notice but there were small gaps in the path which were discovered after reading your reply. I then started over with 1 part and got it to simulate correctly then copied that 15 times. reran the simulation and it simulated correctly. Thanks so much for your tip.
Ernie
Ernie,
It's good to hear you have it sorted, thanks for confirming the cause & fix, this does help folks who search for a solution at a later date,
Regards,
Nick
