535,108 active members*
2,974 visitors online*
IndustryArena Forum > MetalWorking Machines > CNC "do-it-yourself" > single axis controller question
    Feb 2012
    7
    I am looking into building a single stepper machine to automate a reloading press. Essentially I need the stepper to run a certain number of steps at a slow speed and then pause. then with a button press run more to complete the cycle of the machine. preferably there would be a remote mounted button(s) at the machine. has anyone used one of these st-pmc1 single axis controllers. I was looking for the manual but did not see it online. it looks like it should work
    https://www.amazon.com/SainSmart-Ste.../dp/B011NJA38A
    Mar 2004
    393
    Re: single axis controller question
    I have not used that one, .. it looks like it might be even more complicated than it needs to be.
    I've used quite a few of these: https://www.amazon.com/Stepper-Contr...9961818&sr=8-2
    They work very well compared to the other ones I have tried. While you can not control the actual number of steps, you can locate a limit switch to temporarily stop where you want, then continue easy enough. I've mostly used these to create simple power feed systems, and with the right method of switching, they are super controllable.
    For example, I have used a speed pot with built in off switch like an older radio's volume control works. By turning it on, it becomes armed, and with increased turning of the pot, the faster it runs. A simple fwd/reverse switch allows you to change directions with a nice comfortable ramp.
    One could also not use a pot in a LIVE type scenario, but use it to SET a desired speed, and just uses switches to stop/start.
    If you search for DKC-1A on Amazon, I think you can find these for under $15. I love them.... I even bought spares for fun projects.
    Chris L
  1. Need single axis controller for Easy-cnc
    By mwhatch in forum Stepper Motors / Drives
    Last Post: 08-04-2013, 10:00 PM
  2. single axis driver connection question
    By Duaneglee in forum Controller Cards
    Last Post: 01-28-2013, 09:12 PM
  3. Rookie Question...3 axis vs 4 axis controller
    By Ferrari2007 in forum DIY CNC Router Table Machines
    Last Post: 09-14-2009, 02:04 AM
  4. Single Axis Controller to run two motors
    By edo in forum General CNC Machine Related Electronics
    Last Post: 01-09-2007, 12:56 AM
  5. single axis controller
    By robm7 in forum Stepper Motors / Drives
    Last Post: 10-22-2005, 07:30 PM
