528,152 active members*
3,341 visitors online*
Results 1 to 13 of 13
    Jan 2007
    44
    Single Board computer for LinuxCNC
    Anyone successfully using LinuxCNC on a single-board computer?
    Looking to run LinuxCNC with a Mesa card (probably a 7i92) For packaging reasons, i need a single-board computer (not enough cabinet space for a full-size PC)
    Looking for names/models of single-board computers that others have used successfully
    Thanks!
    Mike
    Feb 2008
    623
    Re: Single Board computer for LinuxCNC
    The Gigabyte Brix GB-BXBT1900 is known to work well for this.
    (you need to turn off speed switching in the BIOS and disable power
    management states > C1 to get decent latency and address some video issues)
    Probably many other MiniPCs would work (especial faster ones)
    but they need to be tested
    Nov 2005
    190
    ECS BAT-I/J1800 micro ATX motherboard with a Mesa 6i25+7i76 inside my control cabinet. No problems so far.
    Jan 2009
    327
    Quote Originally Posted by mike944 View Post
    Thanks!
    Mike
    Hello Mike
    I am running PathPilot on a AMD GizmoSphere 1. I have also demonstrated MACH 3 and LinuxCNC.
    I converted a Denford NovaTurn to AC servos;
    https://www.cnczone.com/forums/bench...754-cnc-3.html
    NovaTurn Servo retrofit AMD Gizmosphere iBOB2 PCIe x1 - Denford Software & Machines
    Config;
    AMD GizmoSphere I
    IBOB 2
    MESA 6i25
    MESA 7i77
    Yaskawa SGDA-01AS 100W servos
    Control is +- 10V Torque mode.
    The only problem, AMD no longer makes these. There may be a few still out there?
    Iron-Man
    Jan 2007
    44
    Ok, if the gizmosphere 1 works fine, hopefully the gizmosphere 2 works as well. That's what I found available, and ordered.
    I'm sure I'll be back with lots of questions......
    Thanks!
    Mike
    Jan 2009
    327
    Thanks!
    Mike
    Hello Mike
    The Gizmo II is a little faster but it does not have a SATA port like the Gizmo I. This was a dumb idea.
    There is a unpopulated SATA connector on Gizmo II. I have not added one to my board yet.
    I have used my iBOB 2 for the SATA connector, Unfortunately the schematics for the Gizmo I and II are different.
    The pinouts on the high speed ports for the PCIe interface were reversed. Therefore, all functions on the IBOB 2 work with the Gizmo I.
    The iBOB 2 will only provide a SATA interface, but the PCIe will not function because the signals were switched. My Gizmo IIs are pre-production units that were provided by AMD.
    I already have PathPilot 2 running on the Gizmo II with a Mesa 6i25 attached, I just have not connected any servos yet. Everything fits in a case about the size of a small cigar box.
    https://www.cnczone.com/forums/bench...59408-cnc.html
    NOTE;
    I am also working on a different solution using a different processor, ie not AMD or Intel.
    Iron-Man
    Jan 2007
    44
    It does have an mSATA port, for plugging in a SSD. But, hopefully the micro-SD alone is adequate.
    I just got it, and was surprised by the lack of a VGA port. Going to have to get an adapter to use the older monitor I was planning using, for hdmi to vga
    Mar 2012
    74
    SSD is better in read/write, speed and storage method than SD card ....And, seem someone can run well Mesa 7i96 on Raspberry PI 4?, I really want to use this SBC instead?!
    Apr 2007
    18
    Have you looked into the Beaglebone black sbc it's small runs linuxCNC and uses onboard PRU - programmable realtime units. Should be lots of info on how to wire this up. The one I have came with a DB-25 connector and LinuxCNC preloaded
    Jan 2009
    327
    Quote Originally Posted by wyzarddoc View Post
    Hello wyzarddoc
    I have not looked at the Beaglebone SBC. If it only had a PCIE interface. I have not looked into this SBC, there may be a way to create a PCIE from its IO?
    Iron-Man
    May 2015
    497
    There are a few people using the Raspberry PI4. Combine it with a Mesa 7i96 or 7i76e but I think Mesa are working on a board that connect to the GPIO. But I use the Brix J1900 Peter (PCW) mentioned with a Mesa 7i76e ethernet board which I purchased before the 7i96 was released..
    Rod Webster
    www.vehiclemods.net.au
    Sep 2008
    228
    Quote Originally Posted by rodw View Post
    Ready-to-go SD Card image at: https://www.linuxcnc.org/iso/linuxcnc-2.8.0-pi4.zip
    May 2015
    497
    And also the Odroid H2+ is a cool PC with a bit more grunt then the Gigabyte BRix mentioned earlier
    https://www.hardkernel.com/shop/odroid-h2plus/
    I ran one up with Linuxcnc but I moved it to another project with a 15" touch screen on a press brake.
    Rod Webster
  1. Recommendations on motion control boards & Single Board Computer
    By mike944 in forum Controller & Computer Solutions
    Last Post: 12-12-2018, 09:57 PM
  2. Use of LattePanda Single Board Computer
    By jknee2 in forum Mach Software (ArtSoft software)
    Last Post: 03-20-2017, 12:57 AM
  3. Linuxcnc on Windows Computer?
    By CATCH22 in forum LinuxCNC (formerly EMC2)
    Last Post: 05-08-2016, 02:40 PM
  4. Centurion 6 upgrade to single board computer
    By single phase in forum Milltronics
    Last Post: 03-05-2015, 10:04 PM
  5. 1998 EZ TRAK single board computer
    By reabdet21 in forum Uncategorised MetalWorking Machines
    Last Post: 12-11-2011, 07:15 PM
